Observer derekparks
u-boot & Linux nand drivers
Im having trouble writing an image from Linux into Nand flash and having u-boot boot that image from nand.  Basically the two drivers are not in sync.  In a more simple case, i write a 2K random file from uboot in nand, boot into Linux, read same 2K file from Linux, and see bit differences.
Zynq SoC 7100
Flash is Spansion Nand S34ML02G1
U-boot driver: Zynq_nand.c
Static memory controler: pl353
Linux drivers: pl353 for both nand and memory control
Petalinux 2017.3
Observer derekparks
Re: u-boot & Linux nand drivers
The nand timings we configure in the Linux devicetree for the SMC chip are:
arm,nand-cycle-t0 = <0x4>;
arm,nand-cycle-t1 = <0x4>;
arm,nand-cycle-t2 = <0x1>;
arm,nand-cycle-t3 = <0x2>;
arm,nand-cycle-t4 = <0x2>;
arm,nand-cycle-t5 = <0x2>;
arm,nand-cycle-t6 = <0x4>;
The FSBL sets them the same (using the included one from Petalinux):
EMIT_WRITE(0XE000E014, 0x00449144U)
I must then assume U-boot is using whatever the FSBL configures.
Observer derekparks
I am noticing that u-boot and Linux drivers behave differently on the oob section.  U-boot seems to be doing it correctly as far as the number of bytes it uses for ECC...12 bytes in position 52-63 of the oob section. But Linux only uses 3bytes in position 52-54.
If i write a random binary file in u-boot, boot into Linux, and dump the contents, there are some bits that flip, but here is the OOB section from the first block:
OOB Data: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
OOB Data: ff ff ff ff d4 4a ad 3a aa a3 d2 d3 c2 1b bd d1
If i then erase flash, write the same random binary file from Linux, no bitflips occur and here is the OOB section from the first block:
OOB Data: ff ff ff ff c5 af 03 ff ff ff ff ff ff ff ff ff
 This is strange and am using it as really strong lead.
The ECC data in the OOB depends on the page size:
u32 NandOob16[] = {13, 14, 15}; /**< Ecc position for 16 bytes spare area */
u32 NandOob32[] = {26, 27, 28, 29, 30, 31};    /**< Ecc position for 32 bytes spare area */
u32 NandOob64[] = {52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63};    /**< Ecc position for 64 bytes spare area */
It does look like u-boot is doing the right thing.
Can I see your full device tree node for the NAND, please?
Please, give me few days to investigate this.
Observer derekparks
Attached is workaround patch as i was not able to dig deep enough for root cause.  The patch allows me to write to flash correctly, but reads are still not work correctly.  I verified that i can write a new Linux image to a mtd partition and boot cleanly, but if were to read from that partition to a file, the checksum doesn't match the original.  Additionally from Linux, I can perform nanddump without ecc using the -n flag and the checksum match.  Leaning towards something in pl35x_nand_correct_data as there are only a few bits that differ per page.
One final issue is with mounting jffs2 to a mtd partition.  We are using initramfs, but need persistent storage for configuration files.  A 10MB partition is carved out in the nand and when i perform a jffs2 mount (with flash_erase) i get too many badblocks and jffs2 declines to mount a filesystem.
Observer derekparks
memory-controller@e000e000 {
#address-cells = <0x1>;
#size-cells = <0x1>;
status = "okay";
clock-names = "memclk", "aclk";
clocks = <0x1 0xb 0x1 0x2c>;
compatible = "arm,pl353-smc-r2p1";
interrupt-parent = <0x4>;
interrupts = <0x0 0x12 0x4>;
ranges;
reg = <0xe000e000 0x1000>;
flash@e1000000 {
status = "okay";
compatible = "arm,pl353-nand-r2p1";
reg = <0xe1000000 0x1000000>;
partition@0x00000000 {
label = "boot.bin";
reg = <0x0 0x4000000>;
partition@0x04000000 {
label = "ubootenv";
reg = <0x4000000 0x20000>;
partition@0x04020000 {
label = "kernel";
reg = <0x4020000 0x6400000>;
partition@0x0a420000 {
label = "configfiles";
reg = <0xa420000 0xa00000>;
Coming soon on the web an AR with a patch for this issue.
71078 - 2017.x Zynq-7000 - Embedded Linux: ubi ECC error on S34ML02G1
