Observer zhongxp
u-boot compile error!
1.gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-104) 2. Linux ubuntu 3.13.0-32-generic #57~precise1-Ubuntu SMP Tue Jul 15 03:50:54 UTC 2014 i686 i686 i386 GNU/Linux root@ubuntu:~/build/u-boot-xlnx# make zynq_zed_config # # configuration written to .config # root@ubuntu:~/build/u-boot-xlnx# make scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h UPD include/config.h GEN include/autoconf.mk GEN include/autoconf.mk.dep GEN spl/include/autoconf.mk CHK include/config/uboot.release CHK include/generated/version_autogenerated.h CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CC lib/asm-offsets.s CHK include/generated/generic-asm-offsets.h CC arch/arm/lib/asm-offsets.s CHK include/generated/asm-offsets.h HOSTCC tools/envcrc.o HOSTCC tools/common/env_embedded.o HOSTLD tools/envcrc HOSTCC tools/mkenvimage.o HOSTLD tools/mkenvimage HOSTCC tools/aisimage.o In file included from tools/aisimage.c:10:0: include/image.h:907:27: fatal error: openssl/evp.h: No such file or directory compilation terminated. make[1]: *** [tools/aisimage.o] Error 1 make: *** [tools] Error 2 root@ubuntu:~/build/u-boot-xlnx#
Re: u-boot compile error!
@zhongxp
check this link which has the details of the issue and fix.
-Achutha
Observer zhongxp
a new error as the following
DTC arch/arm/dts/zynq-zc702.dtb
dtc: invalid option -- 'i'
Usage:
dtc [options] <input file>
Are you manually calling DTC or using a script? If manual:
To create a dtb:
dtc -O dtb -I dts -o devicetree.dtb inputfile.dts
To extract a dtb to a dts:
dtc -O dts -I dtb -o out.dts devicetree.dtb
