Visitor tavish_n
u-boot from petalinux is missing most commands
Here is the boot log and printenv contents:
U-Boot 2018.01 (Sep 09 2019 - 07:01:56 +0000) Xilinx Zynq ZC702
Board: Xilinx Zynq
Silicon: v3.1
DRAM:  ECC disabled 512 MiB
MMC:   mmc@e0100000: 0 (SD)
** No device specified **
Using default environment
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
Board: Xilinx Zynq
Silicon: v3.1
U-BOOT for test_boot
## Error: "uenvboot" not defined
## Error: "cp_kernel2ram" not defined
Zynq> printenv
arch=arm
autoload=no
baudrate=115200
board=zynq
board_name=zynq
bootcmd=run default_bootcmd
bootdelay=4
clobstart=0x10000000
console=console=ttyPS0,115200
cpu=armv7
default_bootcmd=run uenvboot; run cp_kernel2ram && bootm ${netstart}
dtbnetstart=@dtbnstart@
fdtcontroladdr=1ffabb10
loadaddr=0x10000000
modeboot=sdboot
netstart=0x10000000
psserial0=setenv stdout ttyPS0;setenv stdin ttyPS0
sdbootdev=0
serial=setenv stdout serial;setenv stdin serial
soc=zynq
stderr=serial@e0001000
stdin=serial@e0001000
stdout=serial@e0001000
vendor=xilinx
Environment size: 589/524284 bytes
I'm using petalinux 2018.3, not doing anything compilcated, just building u-boot with the default settings. I looked at the forums, but couldn't find anybody else facing similar issues. Any ideas what might be wrong?
Re: u-boot from petalinux is missing most commands
Hi @tavish_n
I am not sure exactly how you are building petalinux. I mean whether with BSP or your custom HDF. However, I tried booting uboot on zc702 and here is the printenv log
Zynq> pri
arch=arm
autoload=no
baudrate=115200
board=zynq
board_name=zynq
boot_img=BOOT.BIN
bootdelay=4
bootenv=uEnv.txt
bootenvsize=0x20000
bootenvstart=0x500000
cp_kernel2ram=mmcinfo && fatload mmc ${sdbootdev} ${netstart} ${kernel_img}
cpu=armv7
dfu_mmc_info=set dfu_alt_info ${kernel_image} fat 0 1\\;dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0
dfu_ram=run dfu_ram_info && dfu 0 ram 0
dfu_ram_info=setenv dfu_alt_info image.ub ram $netstart 0x1e00000
dnsip=10.0.2.3
dtb_img=system.dtb
dtbnetstart=0x23fff000
eraseenv=sf probe 0 && sf erase ${bootenvstart} ${bootenvsize}
ethact=ethernet@e000b000
ethaddr=00:0a:35:00:1e:53
fault=echo ${img} image size is greater than allocated place - partition ${img} is NOT UPDATED
fdtcontroladdr=3ffa5360
gatewayip=10.0.2.2
importbootenv=echo "Importing environment from SD ..."; env import -t ${loadbootenv_addr} $filesize
install_boot=mmcinfo && fatwrite mmc ${sdbootdev} ${clobstart} ${boot_img} ${filesize}
install_jffs2=sf probe 0 && sf erase ${jffs2start} ${jffs2size} && sf write ${clobstart} ${jffs2start} ${filesize}
install_kernel=mmcinfo && fatwrite mmc ${sdbootdev} ${clobstart} ${kernel_img} ${filesize}
ipaddr=10.0.2.15
jffs2_img=rootfs.jffs2
kernel_img=image.ub
load_boot=tftpboot ${clobstart} ${boot_img}
load_dtb=tftpboot ${clobstart} ${dtb_img}
load_jffs2=tftpboot ${clobstart} ${jffs2_img}
load_kernel=tftpboot ${clobstart} ${kernel_img}
loadaddr=0x10000000
loadbootenv=load mmc $sdbootdev:$partid ${loadbootenv_addr} ${bootenv}
loadbootenv_addr=0x00100000
modeboot=jtagboot
nc=setenv stdout nc;setenv stdin nc;
netboot=tftpboot ${netstart} ${kernel_img} && bootm
netmask=255.255.255.0
netstart=0x10000000
sd_uEnvtxt_existence_test=test -e mmc $sdbootdev:$partid /uEnv.txt
sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${dtb_img} && run install_dtb
sd_update_jffs2=echo Updating jffs2 from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${jffs2_img} && run install_jffs2
sdbootdev=0
serverip=172.25.120.174
soc=zynq
test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${img} is NOT UPDATED; fi
test_img=setenv var "if test ${filesize} -gt ${psize}; then run fault; else run ${installcmd}; fi"; run var; setenv var
thor_mmc=run dfu_mmc_info && thordown 0 mmc 0
thor_ram=run dfu_ram_info && thordown 0 ram 0
uenvboot=if run sd_uEnvtxt_existence_test; then run loadbootenv; echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi
update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd "install_boot"; run load_boot ${installcmd}; setenv img; setenv psize; setenv installcmd
update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd "install_dtb"; run load_dtb test_img; setenv img; setenv psize; setenv installcmd
update_jffs2=setenv img jffs2; setenv psize ${jffs2size}; setenv installcmd "install_jffs2"; run load_jffs2 test_img; setenv img; setenv psize; setenv installcmd
update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd "install_kernel"; run load_kernel ${installcmd}; setenv img; setenv psize; setenv installcmd
vendor=xilinx
Environment size: 3640/131068 bytes
Visitor tavish_n
Hi @shabbirk,
I could not resolve my issue if I'm using the petalinux flow, but I've for the moment switched to building u-boot separately and building BOOT.BIN separately also.
Tavish
