Observer deepaksingh
ug1085 zynq -ultra scale latest version Linux git repo
For my project i need to write I2C/SPI client drivers and also need to customize the other drivers but the Yocto build available in the ug1144-petalinux-tools-reference-guide user manual doesn't have separate Linux source code.
So please provide the link to download the ug1085 zynq -ultra scale latest version PetaLinux source git repo.
Re: ug1085 zynq -ultra scale latest version Linux git repo
Hi @deepaksingh
You have to  create a petalinux project with BSP, then build the project. It will generate the boot images in xilinx-zcu102-2018.2/images/linux directory after build.
and it will also generate the Linux source also in build/tmp/work-shared/zcu102-zynqmp/kernel-source/ directory.
Below are the build steps for zynqMP using petalinux.
source /proj/petalinux/petalinux-v2018.2-final/settings.sh
petalinux-create --type project -s /proj/petalinux/petalinux-v2018.2_bsps_daily_latest/xilinx-zcu102-v2018.2-final.bsp
petalinux-config
petalinux-build
petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --fpga images/linux/system.bit --pmufw images/linux/pmufw.elf --u-boot  -- This will create an BOOT.BIN
Note: Petalinux should be  installed in your Linux machine. (BSP and petalinux installed version should be same.)
For installation please refer this link:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
Thanks & regards
Aravind
Hi @deepaksingh
You can download the latest Linux source code from this repo :
git clone https://github.com/Xilinx/linux-xlnx
and for petalinux BSP , you can download from this link:https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
Thanks & regards
Aravind
Hi Aravind,
Thank you for the reply. With the link provided below i can download the Linux and BSP but how to flash the kernel build image(uImage). Because after building the Yocto build only two images (BOOT.bin and image.ub) we are copying to SD card while flashing.
So is there any specific way to build the kernel to generate the binaries?
HI @deepaksingh
If you use the BSP , then you no need of separate Linux source code.
The BSP it self will have all the source codes(linux, u-boot,rootfs). This will generate the boot images(BOOT.BIN &image.ub).
For more info you can refer the this link: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1209-embedded-design-tutorial.pdf (page no:47)
You cannot use the uImage, instead you need to use the Image.
copy all images to SDcard and run below command.
fatload mmc 0 80000 Image; fatload mmc 0 4000000 system.dtb;
fatload mmc 0 6000000 rootfs.cpio.gz.u-boot;
booti 80000 6000000 4000000
Thanks & regards
Aravind
Hi Aravind,
In the below i can find only bsp and binaries not bale to get the complete bsp source code.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2017-4.html
Hi @deepaksingh
petalinux-config
petalinux-build
Thanks & regards
Aravind
