ug1209,secure boot problem, bootgen - syntax error "1728(*)]fsbl_a53.elf
I'm learning  secure boot on ultrascale+ mpsoc.
SDK version is 2016.4.
ug1209-embedded-design-tutorial.zip versions:2018.1 and 2018.2 .
Commond:bootgen -p zcu9eg -arch zynqmp -image key_generation.bif
When I use the files in ug1209-embedded-design-tutorial.zip/secure_boot_sd/keys,
it show me an error:
ERROR:BootGen - syntax error
    Line #13, "key_generation.bif".
... ks = 1728(*)]fsbl_a53.elf
Is anyone know what is the problem,thank you.
Re: ug1209,secure boot problem, bootgen - syntax error "1728(*)]fsbl_a53.elf
Please use SDK 2018.1 or 2018.2.   The software used needs to match the document version
