ultra96 simple video opencv error
hi,
I am using for ultra96 board for accelerate a vision algorithm, but when I try to run a simple opencv c++ code it gives me this error. this code totally run in PS(processor) part. I generated all the files using ultra96 bsp and petalinux.
please help
thanks
Re: ultra96 simple video opencv error
Hi @1ymw1,
In petalinux just use the opencv recipes by default whatever is enabled from Yocto https://github.com/Xilinx/meta-petalinux/blob/rel-v2018.3/recipes-core/packagegroups/packagegroup-petalinux-opencv.bb
If you want to enable libv4l, libav configurations in opencv then you need to create a bbappend file as show below
$ mkdir -p <plnx-proj-root>/project-spec/meta-user/recipes-support/opencv
$ vim <plnx-proj-root>/project-spec/meta-user/recipes-support/opencv/opencv_%.bbappend
# opencv_%.bbappend
PACKAGECONFIG_append = "libv4l libav"
In general if you want to use libav then follow below steps.
1. Enable gstreamer packagegroup.
$ petalinux-config -c rootfs ---> Petalinux Package Groups ---> packagegroup-petalinux-gstreamer ---> [*] packagegroup-petalinux-gstreamer
2. Enable the GStreamer1.0-libav package and whitelist the license flag.
$ vim <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
IMAGE_INSTALL_append = " gstreamer1.0-libav"
LICENSE_FLAGS_WHITELIST_append = " commercial_gstreamer1.0-libav"
3. Modify the device-tree to set the CMA(make sure you set appropriate) for video pipeline
$ vim <plnx-proj-root>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
# system-user.dtsi content
/include/ "system-conf.dtsi"
    chosen {
        bootargs = "earlycon clk_ignore_unused cma=1700M cpuidle.off=1";
        stdout-path = "serial0:115200n8";
4. On Target use the below pipeline as example. In my case I have used File-> soft decode(libav) -> Display(using display prot).
root@zcu102-opencv:/run/media/mmcblk0p1# gst-launch-1.0 filesrc location=sintel_trailer-1080p.mp4 ! qtdemux name=demux demux.video_0 ! h264parse ! avdec_h264 ! queue max-size-bytes=0 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Redistribute latency...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:52.192526876
Setting pipeline to READY ...
Setting pipeline to NULL ...
[  896.369727] PLL: shutdown
[  896.375165] PLL: enable
Freeing pipeline ...
I hope this will give some idea and proceed further.
Sandeep
Hi @1ymw1
Please try xfopencv examples,
https://github.com/Xilinx/xfopencv
Best Regards,
Nutan
hi @nutang
thanks for the reply. As far as I know, xfopencv is for use with sdsoc. But how can I use xfopencv with petalinux? (I know if I build a software platform with petalinux I can use it with sdsoc, is that what you mean?)it seems  petalinux is not capable for read video files, thats why v4l error occur. how can I enable it?
Hi @1ymw1
Yes, I just gave you an alternative.
Please refer https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf to enable v4l utilities in kernel
Best Regards,
Nutan
hi @nutang
I read that document from top to bottom. But I couldnt find how to enable v4l in kernel, but instead of that I enabled v4l in rootfs(petalinux-config -c rootfs------->misc------->v4l-utils) and I enabled both v4l-utils and libv4l, but I still have the same problem.
Hi @1ymw1,
Before running the opencv application did you verify the camera captures from command line.
v4l2-ctl --list-devices
Sandeep
hi @sandeepg
I am not trying to open a camera from opencv. I am trying to open a small video file using opencv.
hi @sandeepg , @nutang
any idea???
Hi @1ymw1,
Can you post your application and recipe. In case if you are unable to make it public you can send it private message.
Are you sure you are parsing the video file path correctly?
Also can you try to play the avi file using ffplay.
We have caveat here if you are using gstreamer plugins to decode the video in your opencv app then Ultra96 doesn't have any video coder/decoder in this case you might need to use soft decoder like libav.
One more thing for video applications you need to reserve the cma in kernel as show below.
$ vim project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
    chosen {
        bootargs = "earlycon clk_ignore_unused cma=768M ";
Sandeep
hi @sandeepg,
Here is the  complete petalinux plyvideo app folder I use for play a video clip. And I have tried this with zedboard as well as ultra96. In both cases give the same error(as I have shown in above picture), but if I try with images(lena.jpg), it works without any problems. I have double checked whether the video file and plyvideo file in the same directory (usr/bin).
hi @sandeepg, @nutang,
As my understanding so far(according to this post) v4l is a API for devices like camera, the existing petalinux opencv is built with v4l right? so it does not support for the files (like avi,mp4 etc). so if I want to use opencv for files I have to cross complie the opencv according to this    with ffmpeg enabled and v4l disabled right?, are there any other method to open a video file? please explain.
hi @sandeepg
can you please tell me how to include libav as you have mentioned here,
"We have caveat here if you are using gstreamer plugins to decode the video in your opencv app then Ultra96 doesn't have any video coder/decoder in this case you might need to use soft decoder like libav."
thanks
Hi @1ymw1,
# opencv_%.bbappend
    chosen {
Sandeep
Dear @sandeepg
you are not a human, you are a god.If you are living in LK I will find you and buy you a meal. it works prefectly now, but strangly I didnt do the thrird step you have mentioned here, but it works without device tree configuration. I use petalinux 2018.2.
thank you thank you thank you sooooo much.
