unabe to load driver : xilinx_drm_dri.so
I have installed OpenGL ES 2.0 on Ultrascale ZCU106 . The program to create a simple window is working fine , but the program for creating a triangle it is showing an error :
              "libGL error : unable to load driver : xilinx_drm_dri.so
               libGlL error : driver pointer missing
               libGL error : failed to load driver : xilinx_drm " .
 I think this driver is responsible for rendering .
 I have built the image from the prebuilt image provided by xilinx for ZCU102. Is this could be a problem.
 I am new to xilinx peatalinux so any help provided would be of a great use.
Hi @awneesh,
this driver can be included (http://www.wiki.xilinx.com/Xilinx+DRM+KMS+driver) as a built-in module of the kernel. This can be done when configuring the Petalinux Project:
petalinux-config -c kernel
Then, on the menu, the option to activate it is under Device Drivers -> Graphics support -> Xilinx DRM. To activate it as built-in, Y must be pressed.
After that, build the Linux image should be built again
petalinux-build
Ignacio
Tags (3)
Hi @awneesh,
Refer UG1209 for OpenGL demo example.
Sandeep
