riwa
unable to program FPGA
I'm trying to program the FPGA and boot over an SD card in xc7z020-clg400-1 zynq chip inside parallella, I can't figure out where is the problem, I have did vivado design , generate bitstream, create the FSBL project, and for the u-boot, I just download this one https://github.com/parallella/parallella-flash/blob/master/u-boot.elf, (maybe I should build u-boot?)
Here is the bash terminal
U-Boot 2012.10-00003-g792c31c (Jan 03 2014 - 12:24:08)
I2C:   ready
DRAM:  992 MiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
SF: Detected N25Q128 with page size 64 KiB, total 16 MiB
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Configuring PL and Booting Linux...
Device: SDHCI
Manufacturer ID: 1d
OEM: 4144
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 29.5 GiB
Bus Width: 4-bit
reading parallella.bit.bin
4368184 bytes read
Error: Timeout waiting for FPGA to config.
fpga - loadable FPGA image support
Usage:
fpga [operation type] [device number] [image address] [image size]
fpga operations:
  dump  [dev]                   Load device to memory buffer
  info  [dev]                   list known device information
  load  [dev] [address] [size]  Load device from memory buffer
  loadb [dev] [address] [size]  Load device from bitstream buffer (Xilinx only)
  loadmk [dev] [address]        Load device generated with mkimage
        For loadmk operating on FIT format uImage address must include
        subimage unit name in the form of addr:<subimg_uname>
reading uImage
3391040 bytes read
reading devicetree.dtb
7471 bytes read
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.14.12-parallella-xilinx-
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3390976 Bytes = 3.2 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fffb000, end 1ffffd2e ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.14.12-parallella-xilinx-g40a90c3 (esim@adapteva-dev) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #1 SMP PREEMPT Fri Jan 23 22:01:51 CET 2015
Machine model: Parallella Gen1
bootconsole [earlycon0] enabled
cma: CMA: reserved 128 MiB at 27800000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @e6fe0000 s9024 r8192 d15552 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 252432
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 868820K/1015808K available (4609K kernel code, 217K rwdata, 1544K rodata, 176K init, 209K bss, 146988K reserved, 237568K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc060a7f8   (6154 kB)
      .init : 0xc060b000 - 0xc0637340   ( 177 kB)
      .data &colon; 0xc0638000 - 0xc066e5e0   ( 218 kB)
       .bss : 0xc066e5ec - 0xc06a29f4   ( 210 kB)
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
slcr mapped to f0004000
zynq_clock_init: clkc starts at f0004100
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207951633ns
timer #0 at f0006000, irq=43
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x45e140 - 0x45e198
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72760000, Cache size: 512 kB
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
syscon f8000000.slcr: regmap [mem 0xf8000000-0xf8000fff] registered
bio: create slab <bio-0> at 0
media: Linux media interface: v0.10
Linux video capture interface: v2.00
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switched to clocksource ttc_clocksource
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
bounce pool size: 64 pages
msgmni has been set to 1488
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
io scheduler noop registered
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-2364208
dma-pl330 f8003000.ps7-dma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xuartps e0001000.uart: clock name 'aper_clk' is deprecated.
xuartps e0001000.uart: clock name 'ref_clk' is deprecated.
e0001000.uart: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3124999) is a xu▒console [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0016000
epiphany_init() - shared memory: bus 0x8f000000, phy 0x3f000000, kvirt 0xf1000000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
zram: Created 1 device(s) ...
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
aoe: cannot create debugfs directory
aoe: AoE v85 initialised.
zynq-dr e0002000.usb: Unable to init USB phy, missing?
usbcore: registered new interface driver usbserial
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: timeout waiting on completion
adv7511 0-0039: Failed to write 98 = 3: -110
adv7511: probe of 0-0039 failed with error -110
cdns-i2c e0004000.i2c: 100 kHz mmio e0004000 irq 57
cpufreq_cpu0: failed to get cpu0 regulator: -19
cpufreq_cpu0: failed to get cpu0 clock: -2
cpufreq-cpu0: probe of cpufreq-cpu0.0 failed with error -2
Xilinx Zynq CpuIdle Driver started
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using ADMA
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
mmc0: new high speed SDHC card at address 59b4
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
mmcblk0: mmc0:59b4 SD    29.4 GiB
zynq_pm_ioremap: no compatible node found for 'xlnx,zynq-ddrc-1.0'
 mmcblk0: p1 p2
zynq_pm_late_init: Unable to map DDRC IO memory.
zynq_pm_remap_ocm: no compatible node found for 'xlnx,zynq-ocmc-1.0'
zynq_pm_late_init: Unable to map OCM.
regulator-dummy: disabling
ALSA device list:
  No soundcards found.
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 176K (c060b000 - c0637000)
Mount failed for selinuxfs on /sys/fs/selinux:  No such file or directory
 * Starting Mount filesystems on bootocess ended, respawning with status [ OK ]
 * Starting Signal sysvinit that the rootfs is mounted                   [ OK ]
 * Starting Populate /dev filesystem                                     [ OK ]
 * Stopping Populate /dev filesystem                                     [ OK ]
 * Starting Clean /tmp directory                                         [ OK ]
 * Starting Populate and link to /run filesystem                         [ OK ]
 * Stopping Populate and link to /run filesystem                         [ OK ]
 * Stopping Clean /tmp directory                                         [ OK ]
 * Starting set console keymap                                           [ OK ]
 * Starting Signal sysvinit that virtual filesystems are mounted         [ OK ]
 * Stopping Track if upstart is running in a container                   [ OK ]
 * Starting Bridge udev events into upstart                              [ OK ]
 * Starting Signal sysvinit that remote filesystems are mounted          [ OK ]
 * Stopping set console keymap                                           [ OK ]
 * Starting device node and kernel event manager                         [ OK ]
 * Starting Signal sysvinit that local filesystems are mounted           [ OK ]
 * Stopping Mount filesystems on boot                                    [ OK ]
 * Starting flush early job output to logs                               [ OK ]
 * Starting load modules from /etc/modules                               [ OK ]
 * Starting cold plug devices                                            [ OK ]
 * Starting log initial device creation                                  [ OK ]
 * Stopping flush early job output to logs                               [ OK ]
 * Stopping load modules from /etc/modules                               [ OK ]
 * Starting D-Bus system message bus                                     [ OK ]
 * Starting SystemD login management service                             [ OK ]
 * Starting system logging daemon                                        [ OK ]
 * Starting configure network device security                            [ OK ]
 * Starting mDNS/DNS-SD daemon                                           [ OK ]
 * Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated                                                             [ OK ]
 * Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated                                                             [fail]
 * Starting configure network device                                     [ OK ]
 * Starting Mount network filesystems                                    [ OK ]
 * Starting Failsafe Boot Delay                                          [ OK ]
 * Stopping cold plug devices                                            [ OK ]
 * Stopping log initial device creation                                  [ OK ]
 * Starting load fallback graphics devices                               [ OK ]
 * Stopping load fallback graphics devices                               [ OK ]
 * Starting save udev log and update rules                               [ OK ]
 * Stopping save udev log and update rules                               [ OK ]
 * Starting set console font                                             [ OK ]
 * Stopping Mount network filesystems                                    [ OK ]
 * Stopping set console font                                             [ OK ]
 * Starting userspace bootsplash                                         [ OK ]
 * Stopping userspace bootsplash                                         [ OK ]
 * Starting Send an event to indicate plymouth is up                     [ OK ]
 * Starting configure virtual network devices                            [ OK ]
 * Stopping Send an event to indicate plymouth is up                     [ OK ]
 * Starting Bridge socket events into upstart                            [ OK ]
 * Starting Bridge file events into upstart                              [ OK ]
 * Stopping Failsafe Boot Delay                                          [ OK ]
 * Starting System V initialisation compatibility                        [ OK ]
Starting fake hwclock: loading system time.
Fri Jan 30 01:01:01 UTC 2015
 * Setting up X socket directories...                                    [ OK ]
 * Stopping System V initialisation compatibility                        [ OK ]
 * Starting System V runlevel compatibility                              [ OK ]
 * Starting Parallella Thermal Watchdog                                  [ OK ]
 * Starting save kernel messages                                         [ OK ]
 * Starting OpenSSH server                                               [ OK ]
 * Starting regular background program processing daemon                 [ OK ]
 * Starting deferred execution scheduler                                 [ OK ]
and It stop there
where is the problem?
guillaumebres
to me, the binary file you downloaded for uboot works fine and the problem is related to the linux kernel.
Which kernel are you using?
How did you compile the kernel image?
gw.
Embedded Systems, DSP, cyber
