Participant 365972698@qq.com
uramdisk.image.gz can not be decompressed
   I want to make my own ramdisk image based on the  2015.2-release.tar.xz (http://www.wiki.xilinx.com/Zynq+2015.2+Release) , but when I decompress the uramdisk.image.gz, it seems never to work,the file was not damaged:
root@ubuntu:/work/ramdisk/2015.2-release# ll
total 19840
drwxr-xr-x 5 root  root     4096 Aug 27 20:40 ./
drwxr-xr-x 6 root  root     4096 Aug 27 20:42 ../
-rw-r--r-- 1 root  root 10622952 Aug 27 20:22 2015.2-release.tar.xz
drwxr-xr-x 2 root  root     4096 Aug 27 20:24 tmp_mount/
-rw-r--r-- 1 11562  300  3478648 Jul 30 14:08 uImage
-rw-r--r-- 1 11562  300  6186958 Jul 30 14:08 uramdisk.image.gz
drwxr-xr-x 4 root  root     4096 Aug 27 20:22 zc70x/
drwxr-xr-x 2 root  root     4096 Aug 27 20:22 zed/
root@ubuntu:/work/ramdisk/2015.2-release# gunzip uramdisk.image.gz
gzip: uramdisk.image.gz: not in gzip format
root@ubuntu:/work/ramdisk/2015.2-release# tar -zxf uramdisk.image.gz
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
root@ubuntu:/work/ramdisk/2015.2-release# file  uramdisk.image.gz
uramdisk.image.gz: u-boot legacy uImage, , Linux/ARM, RAMDisk Image (gzip), 6186894 bytes, Thu Jul 30 14:08:02 2015, Load Address: 0x00000000, Entry Point: 0x00000000, Header CRC: 0x36C5DF9E, Data CRC: 0xDCD49C9
Is there any solution for me ?
TONNY
Scholar rfs613
Re: uramdisk.image.gz can not be decompressed
Also the "u" in uramdisk implies that there is a u-boot header present. This 64-byte header would need to be removed before you can work with the remaining cpio archive.
Seems the SSL key for wiki.xilinx.com has expired, so I cannot access any of the content there (Firefox won't even let me add an exception)
check with ubuntu
http://askubuntu.com/questions/291221/error-with-tar-commad-cannot-open-no-such-file-or-directory
Thanks and Regards
Balkrishan
Hi:
    Thanks for your repley!
    But i am confused by the link you give me. It seems that I have a different problem with that.
    I have the right directory, undamaged file, the root user .
    Or ,is the file "uramdisk.image.gz" in the "2015.2-release.tar.xz"  can not be decompressed ?
   My same operation on the  arm_ramdisk.image.gz(http://www.wiki.xilinx.com/Build+and+Modify+a+Rootfs) works    normally. Is there any difference between the two files?
TONNY
A long time ago we were using an initrd ramdisk but now it is an initramfs ramdisk.  These are not tar based files but cpio based.
https://www.kernel.org/doc/Documentation/filesystems/ramfs-rootfs-initramfs.txt
So there is a different process to alter the ramdisk image.
I hope that helps,
John
Scholar rfs613
HI:
    Thanks,the file can be decompressed when I remove the 64 byte header.
    I can see the whole files  in it's mounted directory :
   But  when I boot ZYNQ to the file system ,I can't see any of them .Seems  like that it is empty:
    root@zynq:~# ls
    root@zynq:~#
    root@zynq:~#
   I dont understand, someone get the reason?
TONNY
Sorry, I was in the wrong directory. The default directory is in the home dirctory while the file systerm is mount on /root .
TONNY
