util-linux error when invoked from build-root
I am using buildroot-2013.02 to create an initramfs for Microblaze (Big Indian), selected busybox 1.21.0, e2fsprogs-1.42.7, util-linux-2.20.1
I need to have "mke2fs" in my filesystem, so I selected it from
"Package Selection for the target"  > "Filesystem and flash utilities" > "e2fsprogs" > "mkfs.ext2"
I get the following error when compiling:
../../lib/sysfs.c:244: warning: implicit declaration of function 'fdopendir'
../../lib/sysfs.c:244: warning: assignment makes pointer from integer without a cast
../../lib/sysfs.c: In function 'sysfs_is_partition_dirent':
../../lib/sysfs.c:292: warning: implicit declaration of function 'faccessat'
CCLD libblkid.la
copying selected object files to avoid basename conflicts...
make[5]: Leaving directory `/home/bashar/buildroot-2013.02/output/build/util-linux-2.20.1/libblkid/src'
make[4]: Leaving directory `/home/bashar/buildroot-2013.02/output/build/util-linux-2.20.1/libblkid/src'
CCLD mkswap
CCLD swaplabel
../libblkid/src/.libs/libblkid.a(sysfs.o): In function `sysfs_is_partition_dirent':
: undefined reference to `faccessat'
../libblkid/src/.libs/libblkid.a(sysfs.o): In function `sysfs_opendir':
: undefined reference to `fdopendir'
collect2: ld returned 1 exit status
make[3]: *** [swaplabel] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: *** [mkswap] Error 1
make[3]: Leaving directory `/home/bashar/buildroot-2013.02/output/build/util-linux-2.20.1/disk-utils'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/bashar/buildroot-2013.02/output/build/util-linux-2.20.1'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/bashar/buildroot-2013.02/output/build/util-linux-2.20.1'
make: *** [/home/bashar/buildroot-2013.02/output/build/util-linux-2.20.1/.stamp_built] Error 2
if I unselect ""e2fsprogs", it can compile successfully, but I am doing the whole thing just to get mkfs.ext2 in my system.
I noticed that, when I select "e2fsprogs", there are other features that becomes atoatically selected:
-*- util-linux
-*-   build libuuid and uuid utilities
-*-   build libblkid and blkid utilities
it seems that some header files are missing, anyone had a similar problem ?
ps: does anyone has a .config file that generates initramfs for Microblaze plb?
Best Regards,
B.Romanous
Re: util-linux error when invoked from build-root
I never tried to add mke2fs, but maybe you can try to add it into busybox not in buildroot :
make busybox-menuconfig
(not sure mke2fs exists in busybox....)
I found some (old) post about similar issues :
https://dev.openwrt.org/ticket/4212
google
Hope you will find a solution
PS : why do you say :
Because Microblaze plb is little endian, so be carefull you need a different kernel/compiler if you are using plb instead of axi
anyone? please help!
is there any more information I can provide?
Best Regards,
B.Romanous
google
make busybox-menuconfig worked like a charm
i added mkfs.ext2 and compiled using
make busybox
i copied the following folders :bin, sbin and usr from ~/buildroot-2013.02/output/target to my old initramfs folder ( I replaced the three original folders with these three) and rebuilt the kernel
now i have all the mkfs app working on xlnx linux
thanks a lot my friend, this is so much easier than using using build root
I have a note that Microblaze plb is Big endian while axi is the small endian
thanks again zben :)
Best Regards,
B.Romanous
You're welcome bromanous.
Just some points :
  • You don't really need to do "make busybox" a simple "make" should do the trick : in fact busybox is a part of buildroot, when you do make, it will call "make busybox".
  • You don't have to copy the bin, sbin... folders, normally it is automatic when you do "make"
  • In fact when you want to add something look if it exists in busybox menuconfig, if not go to buildroot : busybox has I said is part of buildroot : it is generally smaller (in term of binary size) and more easy to compile. But buildroot is still required and can be helpfull for exemple to add custom package
Bye and good luck for your project
The problem with buildroot was that it failed to solve the dependencies with the rest of the tools,
when I activated some functions from "e2fsprogs", this in turn activated the build of other functions from "util-linux" package (build libuuid and uuid utilities, build libblkid and blkid utilities)
however, the make process would fail due the errors posted in the main thread. I wish I can figure out the solution to:
and use buildroot to generate the ready initramfs.cpio file but I had to reside to that hack to keep my project going.
if anyone knows what triggered theses errors above, please share your ideas with us.
Best Regards,
B.Romanous
