vivado, sdk and petalinux installation on ubuntu 16.04
I want to install Petalinux on Linux machine. At present I have ubuntu 16.04.03 Desktop with RAM 4GB.
I have downloaded the petalinux-v2018.3-final-installer.run from xlinx website. As per the document from open source xlinx before installing petalinux need to install vivado and sdk. I also downloaded the Vivado and sdk from Xilinx xilinx Xilinx_SDK_2018.3_1207_2324_Lin64.bin, Xilinx_Vivado_SDK_Web_2018.3_1207_2324_Lin64.bin files. But could you guide me steps how to install vivado, SDK and petalinux on ubuntu machine and is it mandatoey to have RAM 8GB .
Raghuram
Mentor xilinxacct
Mentor
Re: vivado, sdk and petalinux installation on ubuntu 16.04
Thanks for support. I have  tried installing the Petalinux installer using below command and failing with the below errors
# ./petalinux-v2018.3-final-installer.run ../peta_installer/
Error :
INFO: Checking installation environment requirements...
awk: read error (Bad address)
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
/home/tcs/peta-linux/petalinux_installation_log
./petalinux-v2018.3-final-installer.run: line 139: /tmp/tmp.Co4az5SqJP/: Is a directory
ERROR: Failed to extract Petalinux installer..
Could you help me to resolve this error.
Raghuram
Mentor xilinxacct
Mentor
@raghuram1a
Slightly different topic than the original post, but the new issue may be being root or not.
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-2016-4-installation-fail/td-p/740706
If that works, please mark as solution accepted. Also, Kudos welcomed :-)
I am running as normal user still same issue facing
   /home/tcs/peta-linux/install_peta/petalinux_installation_log
./petalinux-v2018.3-final-installer.run: line 139: /tmp/tmp.mvVCKJrEP9/: Is a directory
ERROR: Failed to extract Petalinux installer...
could you help me.
waiting for reply could anyone help me
