08-12-2019 06:43 AM
hi ,
I'm trying to get Linux framebuffer output with VDMA and AXI4-Stream to Video Out. The hardware is Trenz Electronic TE820 XCZU4EV SOM board,and a custom carry board.
The kernel version is linux-xlnx-2018.2. And the display hardware pipeline is depicted below:
vdma-[remap]-(rgb2yuv)-(cresample)-(osd)-[axi2vid]-adv7511 vdma-- | | axiclkgen ->vtc
When the kernel started, I got those panic message:
[ 2.248924] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff800ab20000 [ 2.258020] Internal error: : 96000210 [#1] SMP [ 2.262511] Modules linked in: [ 2.265540] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.14.0 #49 [ 2.271506] Hardware name: Trenz TE820 (DT) [ 2.275659] task: ffffffc06d846d00 task.stack: ffffff8008038000 [ 2.281543] PC is at xilinx_vtc_reset+0x14/0x30 [ 2.286041] LR is at xilinx_vtc_probe+0xcc/0x168 [ 2.290624] pc : [<ffffff800854c4cc>] lr : [<ffffff800854c604>] pstate: 60000045 [ 2.297975] sp : ffffff800803bb40 [ 2.301263] x29: ffffff800803bb40 x28: ffffff8008e06f28 [ 2.306539] x27: 0000000000000007 x26: ffffff8008df9068 [ 2.311815] x25: 0000000000000000 x24: ffffff8008e59000 [ 2.317092] x23: ffffffc06da92018 x22: ffffffc06db90100 [ 2.322368] x21: ffffffc06db29010 x20: ffffffc06ffcf848 [ 2.327645] x19: ffffffc06db90098 x18: 0000000000000001 [ 2.332921] x17: 0000000000000001 x16: 0000000000000019 [ 2.338198] x15: ffffffffffffffff x14: ffffff808803ba15 [ 2.343474] x13: ffff000000000000 x12: 0000000000000010 [ 2.348751] x11: 0101010101010101 x10: ffffffff7f7f7f7f [ 2.354027] x9 : 0000000000000000 x8 : ffffffc06c875300 [ 2.359304] x7 : ffffffc06c875348 x6 : ffffffc06c875348 [ 2.364580] x5 : ffffffc06c875648 x4 : ffffffc06db29210 [ 2.369857] x3 : ffffffc06ce21680 x2 : ffffff800ab20000 [ 2.375133] x1 : ffffff800ab20000 x0 : ffffffc06db90098 [ 2.380411] Process swapper/0 (pid: 1, stack limit = 0xffffff8008038000) [ 2.387070] Call trace: [ 2.389494] Exception stack(0xffffff800803ba00 to 0xffffff800803bb40) [ 2.395896] ba00: ffffffc06db90098 ffffff800ab20000 ffffff800ab20000 ffffffc06ce21680 [ 2.403681] ba20: ffffffc06db29210 ffffffc06c875648 ffffffc06c875348 ffffffc06c875348 [ 2.411466] ba40: ffffffc06c875300 0000000000000000 ffffffff7f7f7f7f 0101010101010101 [ 2.419251] ba60: 0000000000000010 ffff000000000000 ffffff808803ba15 ffffffffffffffff [ 2.427035] ba80: 0000000000000019 0000000000000001 0000000000000001 ffffffc06db90098 [ 2.434821] baa0: ffffffc06ffcf848 ffffffc06db29010 ffffffc06db90100 ffffffc06da92018 [ 2.442605] bac0: ffffff8008e59000 0000000000000000 ffffff8008df9068 0000000000000007 [ 2.450391] bae0: ffffff8008e06f28 ffffff800803bb40 ffffff800854c604 ffffff800803bb40 [ 2.458176] bb00: ffffff800854c4cc 0000000060000045 ffffffc06db29010 ffffffc06db90100 [ 2.465961] bb20: ffffffffffffffff ffffff8008e59000 ffffff800803bb40 ffffff800854c4cc [ 2.473746] [<ffffff800854c4cc>] xilinx_vtc_reset+0x14/0x30 [ 2.479282] [<ffffff800854822c>] xilinx_drm_crtc_create+0x194/0x3b8 [ 2.485510] [<ffffff8008548b1c>] xilinx_drm_platform_probe+0x74/0x3c8 [ 2.491910] [<ffffff8008569ab0>] platform_drv_probe+0x58/0xb8 [ 2.497620] [<ffffff8008567bcc>] driver_probe_device+0x2bc/0x440 [ 2.503589] [<ffffff8008567e50>] __driver_attach+0x100/0x118 [ 2.509211] [<ffffff800856594c>] bus_for_each_dev+0x4c/0x98 [ 2.514747] [<ffffff80085673a0>] driver_attach+0x20/0x28 [ 2.520023] [<ffffff8008566db4>] bus_add_driver+0x1f4/0x280 [ 2.525560] [<ffffff8008568898>] driver_register+0x60/0xf8 [ 2.531008] [<ffffff8008569a00>] __platform_driver_register+0x40/0x48 [ 2.537411] [<ffffff8008dc2c98>] xilinx_drm_private_driver_init+0x18/0x20 [ 2.544157] [<ffffff80080839a8>] do_one_initcall+0x38/0x120 [ 2.549693] [<ffffff8008da0cd4>] kernel_init_freeable+0x138/0x1d8 [ 2.555748] [<ffffff8008a3b640>] kernel_init+0x10/0x100 [ 2.560938] [<ffffff8008084a88>] ret_from_fork+0x10/0x18 [ 2.566216] Code: d5033e9f 52b00001 b9000041 f9400001 (b9400021) [ 2.572272] ---[ end trace 97be0d45cc5b664f ]--- [ 2.576869] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 2.576869] [ 2.585936] SMP: stopping secondary CPUs [ 2.589828] Kernel Offset: disabled [ 2.593288] CPU features: 0x002004 [ 2.596660] Memory Limit: none [ 2.599690] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 2.599690]
The PC is at : ffffff800854c4cc,I use the addrline tool to find the line
hsq@hsq-vm:~/projects/opensouce/kernel/zynq/linux-xlnx-xilinx-v2018.2$ aarch64-linux-gnu-addr2line -f -e vmlinux ffffff800854c4cc __raw_readl
The __raw_readl() funtction cause the kernel panic. (xilinx_drm_read() -> readl() -> readlrelaxed() -> __raw_readl() )
I comment the function call xilinx_drm_read() in xilinx_vtc_probe(),the panic disappear,but it's just a temporary workaround.
/* probe vtc */ struct xilinx_vtc *xilinx_vtc_probe(struct device *dev, struct device_node *node) { struct xilinx_vtc *vtc; const struct of_device_id *match; struct resource res; int ret; match = of_match_node(xilinx_vtc_of_match, node); if (!match) { dev_err(dev, "failed to match the device node\n"); return ERR_PTR(-ENODEV); } vtc = devm_kzalloc(dev, sizeof(*vtc), GFP_KERNEL); if (!vtc) return ERR_PTR(-ENOMEM); ret = of_address_to_resource(node, 0, &res); if (ret) { dev_err(dev, "failed to of_address_to_resource\n"); return ERR_PTR(ret); } vtc->base = devm_ioremap_resource(dev, &res); if (IS_ERR(vtc->base)) return ERR_CAST(vtc->base); //xilinx_vtc_intr_disable(vtc, VTC_IXR_ALLINTR_MASK);//temp debug vtc->irq = irq_of_parse_and_map(node, 0); if (vtc->irq > 0) { ret = devm_request_irq(dev, vtc->irq, xilinx_vtc_intr_handler, IRQF_SHARED, "xilinx_vtc", vtc); if (ret) { dev_warn(dev, "failed to requet_irq() for vtc\n"); return ERR_PTR(ret); } } //xilinx_vtc_reset(vtc);//temp_debug return vtc; }
Any iedas?
BestRegards,
HSQ
08-14-2019 12:52 AM
aarch64-linux-gnu-addr2line -f -e vmlinux ffffff80085690b8
__raw_readl
/home/hsq/projects/peta_project/xilinx-vcu-trd-zcu106-zu7-v2018.2/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/include/asm/io.h:90
#define __raw_readl __raw_readl static inline u32 __raw_readl(const volatile void __iomem *addr) { u32 val; asm volatile(ALTERNATIVE("ldr %w0, [%1]", "ldar %w0, [%1]", ARM64_WORKAROUND_DEVICE_LOAD_ACQUIRE) : "=r" (val) : "r" (addr)); return val; }
line 90 is marked line.
08-14-2019 07:20 PM
08-14-2019 08:10 PM
hi
mpsoc平台上,目前没有使用旧的drm框架的例子(driver/gpu/drm/xilinx),至少我还没有看到。我只能根据以前在zynq7000上的经验来搭建IPI。我想问下,你的工程中像素时钟是怎么提供的?按你之前的帖子的设备树,像素时钟就是vid_s_axi_clk吗? 你对外的显示接口是什么?
08-14-2019 08:52 PM
08-16-2019 06:35 AM
hi
update about this thread:
I remove devicetree about drm part,but keep the boot.bin the same as before. I want to use devmem to read the vtc's registers.
Here are the Base Address of the IPI.
all those base address are auto assigned.
here are devmem read result:
root@CHFW:~# devmem 0x80040000 0x00040063 root@CHFW:~# devmem 0x80030000 0x00000000 root@CHFW:~# devmem 0x80020000 0x00000000 root@CHFW:~# devmem 0x80010000 0x00000000 root@CHFW:~# devmem 0x80050000 [ 1466.648378] Synchronous External Abort: synchronous external abort (0x92000210) at 0x0000007f88ada000 Bus error
read vtc cause bus error. The error look the same as vtc driver probe 's panic;
Two VDMA's address reange only 4K(auto assigned ).
BestRegards
HSQ
08-16-2019 07:36 PM
