watchdog timed out. Internal reset not enabled?
Hi, all
board:zc706
linux:petalinux2016.02
I have experienced a problem recently. when I open the watchdog "/dev/watchdog", but don't write it. wait for a while,the console print the log "watchdog timed out. Internal reset not enabled", but my board don't reset.
who can help me, and give me some hints.thanks in advance.
Tom
Re: watchdog timed out. Internal reset not enabled?
Hi @atower
The example provided in the wiki page is for the MPSoC so when using SoC there are some changes in the device-tree that you may consider. As you pointed in your previous post the watchdog controller default description is the following one:
watchdog0: watchdog@f8005000 {
     clocks = <&clkc 45>;
     compatible = "cdns,wdt-r1p2";
     interrupt-parent = <&intc>;
     interrupts = <0 9 1>;
     reg = <0xf8005000 0x1000>;
     timeout-sec = <10>;
As you can see the clocks property is defined in the default template so there is no requirement to add it in the top file. However as the wiki page indicates the reset-on-timeout property have to be added in your description.
So if you want to have the reset feature this is the required dts entry:
&watchdog0 {
    status = "okay";
    reset-on-timeout;
Once you boot the Linux image you can check if your new properties has been loaded properly in the boot process and then run the "echo s > /dev/watchdog0" command to run the watchdog reset.
Ibai
check this link
http://www.wiki.xilinx.com/Cadence+WDT+Driver
Thanks and Regards
Balkrishan
Hi,Balkrishan
Thanks for your reply, I have another question to consult you. what's the differences between "/dev/watchdog" and "/dev/watchdog0"? which watchdog is the "candence wdt" corresponded?
Tom
Hi, Balkrishan
after I add
&watchdog0 {
    status = "okay";
    clocks = <&clk100>;
 in ${PETALINUX_PORJECT}/subsystems/linux/configs/devie-tree/system-top.dts , run petalinux-build , there is a error, print "Reference is non-existent node or label "clk100",
my board is zc706, what should I add "clocks = " instead of  clk100?
my ${PETALINUX_PORJECT}/subsystems/linux/configs/devie-tree/zynq-7000.dtsi watchdog show below
     timeout-sec = <10>;
Tom
if I add
&watchdog0 {
    status = "okay";
 run "petalinux-build" successfully, and run "echo s > /dev/watchdog0", but it still print "Watchdog timed out. Internal reset not enabled"
Why? did I miss some procedures?
Tom
Hi @atower
     timeout-sec = <10>;
&watchdog0 {
    status = "okay";
    reset-on-timeout;
Ibai
Hi,ibaie
Thanks for your reply, follow your solution, the "/dev/watchdog0" can work successfully. If I want to modify the timeout time, e.g, defautl timeout time is 10s, if I want to modify to 5s, what should I do. I'm try to simply modify "timeout-sec = <10>;" to "timeout-sec = <5>;" but it failed, it's still 10s timeout.
Thanks again.
Tom
Re: watchdog timed out. Internal has enabled,but the system do not reboot
i  use the watchdog with this link http://www.wiki.xilinx.com/Cadence+WDT+Driver,the devicetree i set the reset-on-timeout
i write the cmd : echo s > /dev/watchdog0 ,but after 10 seconds ,the system  is  halted and not reboot.
I want the system reboot when watchdog time out,but the system is halted now.the linux kernel release is 2015.3,i dont konw what i should do ?
were u able to resolve this?
Hi ,
What is  your boot mode that you are using?
