sulcas.mindaugas
webkitgtk do_compile failed
Hello everyone,
I have been trying to build petalinux image for my ultra96 board with wayland backend but everytime I am running petalinux-build my computer freezes or shows error webkitgtk do_compile failed. I guess my system runs out of ram becouse while building webkitgtk I was watching my system resoursces and during ld process memory usage rises up to 94% and then my computer freezes. I have tried to reduce parallel jobs through petalinux-config to 1 but it didn't helped. Is there any way to successfully build webkitgtk without adding more ram? My computer has 8GB of ram and I am using Petalinux 2018.3 toolset.
sulcas.mindaugas
The problem can be solved by adding more RAM to PC or by adding / increasing swap memory. Build time will be much longer if using swap memory.
sulcas.mindaugas
