where is pre-canned AMP solution (Linux + FreeRTOS)?
My Zynq board ZC702 arrived yesterday :)
My goal is to use "Asymmetric Multi-Processing (AMP) mode with
... FreeRTOS on one core and Linux running on the other core".
On "Zynq-7000 SoC Operating Systems" page
(http://www.xilinx.com/products/silicon-devices/soc/zynq-7000/operating-systems/)
I read:
"Xilinx provides a pre-canned AMP solution, to simplify your software development on Zynq-7000 EPP platform."
I could not find this "pre-canned solution" on Xilinx web-site.
Where is it?
Pramod Ranade
Re: where is pre-canned AMP solution (Linux + FreeRTOS)?
Finally I managed to get Linux and FreeRTOS running on core0 and core1 respectively.
johnmcd of Xilinx gave me Linux/standalone solution. I replaced standalone with
FreeRTOS port - which I downloaded from FreeRTOS web-site. Unfortunately, the
FreeRTOS port was written with the assumption that it will run on core0. I had to
do something to make it run on core1. Then I had to fix some errors. Unfortunately,
I can't remember what all changes I made, but finally I have it working.
On FreeRTOS, I used their LED blinking example, but also added one more task
of my own. And with some logic in PL, I could implement a filter. Get input from
XADC and throw filtered output to DAC (on the AMS101 board).
I am ok to share this with others, but don't know how to?
Pramod Ranade
Tags (4)
Hi pvranade,
Yes we do have an AMP design (Linux and freeRTOS).
Can you contact your local FAE about the availability of this for you.
Kind regards,
Gareth
Gareth,
Thanks!
Will contact Xilinx India now.
Pramod Ranade
Visitor davidomoto
Is it possible to make this AMP design available for download?
I contacted my FAE and asked him specifically about the AMP design as referenced on the Zynq Operating Systems page.  He didn't know anything about it and just told me that FreeRTOS could be downloaded from www.freertos.com.
Visitor cs00brp
Hi, I'm also trying to find the pre-compiled version of freeRTOS for the Zynq board.  Is there one out there?  HAs anyone a link to any useful info about getting freeRTOS working on this chip or is it better just compiling it my self.
Still not sure if I just put freeRTOS on both cores or linux + freeRTOS. will be using one core of all the communication between the host PC and the FPGA fabric and the second core to do some softreal time control.
Bren
Pramod Ranade
Tags (4)
Participant madboat
pvranade,
Either of the two things that you mentioned in your previous post (linux & freertos or linux & standalone) would be useful to me. If you've got some sharing method that you developed since you posted let me know. otherwise, I've got up a personal Dropbox that we can use, but to do a file transfer I need an e-mail address. if you don't mind, hit me up at jtrout@picocomputing.com.
Jason
Visitor davidomoto
I'm also very interested in the AMP solution.  Maybe you can post your project here:
http://www.zedboard.org/projects
and myself or someone else can port this over to the ZedBoard.
Dave
madboat, davidomoto
Here is link to the compressed project folder:
AMP Linux / FreeRTOS project folder
And some notes in this document.
Pramod Ranade
Observer matteo.geromin
i'm trying to run your project on the Zedboard, with Linux running on core #0 and a baremetal application on core #1.
The application is a simple hello-world.
I just modify my fsbl as you suggest, to make it load u-boot and another binary file. But the result is that only u-boot is running after fsbl.
I also modified ldscrip.ld of my application to reflect the 512MB of ddr ram on the Zedboard.
What are the modification that you made to the application?
You also modified something in u-boot and kernel?
ThankYou
Matteo
Matteo,
Sorry, I can't remember what all changes I made.
But if you download the Linux+FreeRTOS project from my
dropbox (link in previous post), then you don't need to
make any changes. You may replace FreeRTOS by
bare metal application if you like.
With this project, the board should boot Linux on core0.
Then at the Linux prompt, type this command:
/mnt/softUart.elf &
It will start softUart application in background.
Then type this command:
/mnt/rwmem.elf 0xfffffff0 0x30000000
By writing 0x30000000 to location 0xfffffff0, the core1
will be started.
Pramod Ranade
ThankYou!!!
these are the information that i wanted.
Now i'm able to run Linux baremetal AMP.
thanx
Matteo
Visitor dpryan
Hi Pramod,
I'm having trouble getting your project to build in SDK.
I seems like I may be missing some files as specified in SDK: Xilinx Tools>Repositories
These two paths are specified:
D:/MTech/Project/FreeRTOS/Xilinx_Zynq/sw/repo
D:/MTech/Project/Zynq_Projects/amp_14.3/src_amp/sdk_repo
I resolved the first one by pointing it to the files I found here:
http://interactive.freertos.org/entries/21922816-updated-xilinx-freertos-port-for-zynq-to-sdk-14-2-release
I updated the tcl and mld file to use "standalone_v3_07_a" as specified in the documentation so it would build with 14.3
However, I'm not sure what files are supposed to be at the second path. Everthing in your project builds except for  amp_cpu1_bsp, which cannot find os standalone_amp 3.07.a
Is this related to the second path?
David
David,
Yes, it is related to the second path.
That is what mcdougall of Xilinx had given me.
I replaced the "standalone" part with FreeRTOS.
I was assuming that the large zip file I shared via dropbox
includes everything needed - since others were able to
build from that successfully. Do you think some files
are missing?
Pramod Ranade
Visitor dpryan
Hi Pramod,
I really think the source files are missing.
I don't know how Matteo (and possibly others) got it working without it.
I unzipped your projected and searched the contents of all files for "standalone_amp."
That turned up a bunch of *.o files in this directory which basically just had the missing "repository path" embedded in the compiled object code:
\amp_linux_freertos\amp_linux_freertos.sdk\SDK\SDK_Export\amp_cpu1_bsp\ps7_cortexa9_1\libsrc\standalone_amp_v3_07_a\src\*.o files
The only other mention of standalone_amp was this block in SDK_Export\amp_cpu1_bsp\system.mss:
BEGIN OS
 PARAMETER OS_NAME = standalone_amp
 PARAMETER OS_VER = 3.07.a
 PARAMETER PROC_INSTANCE = ps7_cortexa9_1
END
 That block is what is causing the problem since it can't find standalone_amp.
Perhaps there is a way to make the missing standalone_amp .mld file from the object code, but I think the source files are missing which makes it impossible to clean/rebuild.
What do you think?
David,
Not sure if this will help, but I am attaching the folder
D:\MTech\Project\Zynq_Projects\amp_14.3\src_amp\sdk_repo
Let me know if something else is missing too.
Pramod Ranade
Visitor dpryan
Thanks Pramod!
That was exactly what I needed. Everything in SDK compiles now.
-David
Visitor dpryan
Hi Pramod,
Can you please post your device tree source (dts) file? I'm trying to get this running on the Zedboard which requires an entirely different device tree, but I'd like to see what changes you made (maxcpus=1, etc.)
Thanks!
dpryan,
Here is dts file.
I did not create or even edit it.
Pramod Ranade
Hiee pramod
what changes does it require to run ur prjct in 14.4? is there any? One more question can I do posix programming like xilkernel in linux using pthread library..do u have tried?is it possible
Tusu,
I opened the same project in 14.4 and it works.
Seems that no changes are needed.
I did not modify any drivers or kernel level stuff.
But I used pthread library in my user space application and it works well.
Pramod Ranade
Hiee pramod
Thanx for ur rapid reply....
" But I used pthread library in my user space application and it works well."
need little bit explanation amonge these...My linux is booting from sd card of zynq and in sdk I have to write the application by selecting linux as my os...when I shall create a blank c project in linux...Am i have to just include "Pthread.h" and write the subsequent posix pthread_create(), is it enough that my code will build and shows thread are created? does it enough.....share just the format of ur application which executed on linux using pthread if possible
regards
Tusu
Tusu,
Yes, that is exactly how I did it. e.g.
	if (pthread_create(&tid, NULL, &doStdIn, NULL) != 0)
		printf("Error while creating thread!\n") ;
	else
		printf("Thread created successfully!\n") ;
Pramod Ranade
Hiee
Thanx..Pthread works for me too. Here u have talk aboout AMP soln but I need SMP..let me clear my confusions....The linux which I have booted from sd card is it running on dual ARM core? I mean same linux on both the core? if yes, then how it can be done that one part of my application runnig on cpu 0 and another part running on cpu1 then how these two aplication could communicate? via shared memory?
The links had been broken for some time.
Here are new links.
Some notes in this document
But the above solution was made in Dec. 2012 - when no reference design
was available from Xilinx. Now I suspect better reference designs
are available from Xilinx - may be XAPP1078 ?
Pramod Ranade
Visitor prasanna_mn
I am using Xilinx Tools V 2016.2 and petalinux v2016.2. I need to boot linux on cpu0 and freertos on cpu1.
I am able to boot linux on cpu0. I am not getting how to do amp. I followe ug1156. only linux is booting on cpu0, can any one help me out in booting amp on zynq zc702.
Thanks in advance
prasanna
Also take a look at UG1186
Visitor rsgrimes
Hi Prasanna,
Did you ever get this working?  I'm trying to get the same thing working on a MicroZed board, using 2016.2 Vivado and PetaLinux.  I can't figure out what to do, beyond getting a simple one-core Linux build using the MicroZed BSP as a starting point.
