Visitor xienima
where is the kernel source code located in Petalinux2016.4?
I want to custom the code of sd driver in Petalinux2016.4,but I can find the kernel source in Petalinux2016.4,where is the kernel source come from when I use Petalinux to build an image?
Re: where is the kernel source code located in Petalinux2016.4?
@xienima,
you can find the source code in below path (e.g. for zynq-7000) you can find the similar path for zynqmp
<petalinux project>/build/tmp/work-shared/plnx_arm/kernel-source/
Kranthi
Best Regards
Kranthi
Visitor xienima
I found the source coude after building the whole project in this path,and I edit the SD driver code,then I built the project again,but It was invalid.The code in this path restored.
