maikonnascimento
wherer to set CMA for Petalinux
I'm here battling to use DMA + Petalinux , following
https://github.com/bperez77/xilinx_axidma
and it recognizes the DMA channels, but now with my testbench,
I get :
axidma: axidma_chrdev.c: axidma_mmap: 285: Unable to allocate contiguous DMA memory region of size 8294400.
axidma: axidma_chrdev.c: axidma_mmap: 287: Please make sure that you specified cma=<size> on the kernel command line, and the size is large enough.
and I tried to set CMA at system-user.dtsi (I'm using JTAG to program FPGA and Kernel):
chosen {
        bootargs = "console=ttyPS0,115200 CMA=28MB earlyprintk";
        stdout-path = "serial0:115200n8";
but I do not know if this is the place to set it , I went thought petalinux-config -c kernel and rootfs , but no luck.
Tags (3)
maikonnascimento
somebody already answered it , and the commands are :
petalinux-config -c kernel:
Go to kernel features
Make sure the following settings are met:
o Contiguous Memory Allocator
 True
o CMA debug messages (DEVELOPMENT) (if you want...)
 True
Then enable and set the CMA value:
Go to Device Drivers / Generic Driver options
o DMA Contiguous Memory Allocator
 True
o Size in Mega Bytes
 25 (for example)
then when I load the driver I get :
cma: cma_alloc(cma c184d420, count 8, align 3)
cma: cma_alloc(): returned effbf900
cma: cma_alloc(cma c184d420, count 1, align 0)
cma: cma_alloc(): returned effbf880
cma: cma_alloc(): returned effbfa00
cma: cma_alloc(): returned effbf8a0
axidma: axidma_dma.c: axidma_dma_init: 718: DMA: Found 1 transmit channels and 1 receive channels.
axidma: axidma_dma.c: axidma_dma_init: 720: VDMA: Found 0 transmit channels and 0 receive channels.
and from dmesg
cma: dma_contiguous_reserve(limit ffffffff)
cma: dma_contiguous_reserve: reserving 25 MiB for global area
maikonnascimento
 True
 True
 True
 25 (for example)
and from dmesg
