x11 forwarding video clip
hello friends,
I have problem with x11 forwarding a video with simple opencv app. I tried x11 to forward an image with simple opencv app and it works without any problem, but when I try to use a simple video clip, I get this error
Failed to query video capabilities: Inappropriate ioctl for device
libv4l2: error getting capabilities: Inappropriate ioctl for device
VIDEOIO ERROR: V4L: device Ben.mp4: Unable to query number of channels
(showimage:1261): GLib-GObject-CRITICAL **: g_object_set: assertion 'G_IS_OBJECT                                   (object)' failed
Error opening video stream or file
The Ben.mp4 is the video clip I am trying to use with opencv. here is my simple opencv code
#include <opencv2/opencv.hpp>
#include <iostream>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
using namespace std;
using namespace cv;
int main(int argc, char *argv[])
    VideoCapture cap("Ben.mp4");
  // Check if camera opened successfully
  if(!cap.isOpened()){
    cout << "Error opening video stream or file" << endl;
    return -1;
  while(1){
    Mat frame;
    // Capture frame-by-frame
    cap >> frame;
    // If the frame is empty, break immediately
    if (frame.empty())
      break;
    // Display the resulting frame
    imshow( "Frame", frame );
    // Press  ESC on keyboard to exit
    char c=(char)waitKey(1);
    if(c==27)
      break;
  // When everything done, release the video capture object
  cap.release();
  // Closes all the frames
  destroyAllWindows();
    return 0;
please help.
thanks
Re: x11 forwarding video clip
Hi @yisonglee
it is not a problem with x11, if you use zynqmp with display port you will face to the same problem. this problem is regarding with liav and ffmpeg, please refer this answer given by Sandeepg. I didnt do the third step in this method but it worked without that step. please read that thread top to bottom, I used this method for ultra96 board and zedboard. wish you the very best.
Visitor yisonglee
Hi,I encounted the same problem with you. My video cannot be opened by VideoCapture open(). Can you give me some advice? Thanks.
Hi @yisonglee
Visitor yisonglee
Hi @1ymw1
My board is ZCU102 zynqmp. As your suggest, i download gst-libav-1.12.2.tar.xz and place it in the petalinux2018.2 path. Then i did as Sandeepg's solution(step1 &step2). Now, my project works perfectly.BTW,  you are god too.  thanks for your really really really kinds help.
Best Regards.
Yisong
hi @yisonglee
I am glad that it helped you.
