jamead
xemacps e000b000.ps7-ethernet: eth0: no PHY setup
I am trying to bring up Petalinux 14.2 on a Zynq Avnet Mini-Module.    I am following UG980 (Board Bringup Guide) and did the following
1.   $petalinux-create --type project --template zynq --name test
2.   copy over the system.hdf file from vivado
3.   $ petalinux-config --get-hw-description -p <plnx-proj-root>
The image.ub file is generated and boots linux, but ethernet is not working   (Ethernet works with u-boot)
I imagine that the dts file is not getting populated with the correct entries for the phy chip, because how would the tools even know, but I don't see how I can tell the petalinux tools what the correct phy should be?
Here is the last line of the boot process...
NET: Registered protocol family 10
root@xbpm:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:A6:E5
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:1296 (1.2 KiB)
          Interrupt:54 Base address:0xb000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
And here are all the messages....
Starting kernel ...
Linux version 3.14.2-xilinx (mead@carbon) (gcc version 4.8.1 (Sourcery CodeBench Lite 2013.11-53) ) #2 SMP PREEMPT Thu Jul 31 18:38:14 EDT 2014
Machine model: xbpm
bootconsole [earlycon0] enabled
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @eefd3000 s10752 r8192 d13824 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260624
Kernel command line: console=ttyPS0,115200 earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1023480K/1048576K available (4835K kernel code, 310K rwdata, 1776K rodata, 3642K init, 5337K bss, 25096K reserved, 270336K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc067cf7c   (6612 kB)
      .init : 0xc067d000 - 0xc0a0ba00   (3643 kB)
      .data &colon; 0xc0a0c000 - 0xc0a598a8   ( 311 kB)
       .bss : 0xc0a598b4 - 0xc0f8fd88   (5338 kB)
        RCU lockdep checking is enabled.
        Dump stacks of tasks blocking RCU-preempt GP.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
ps7-slcr mapped to f0004000
zynq_clock_init: clkc starts at f0004100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
ps7-ttc #0 at f0006000, irq=43
Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
... MAX_LOCKDEP_SUBCLASSES:  8
... MAX_LOCK_DEPTH:          48
... MAX_LOCKDEP_KEYS:        8191
... CLASSHASH_SIZE:          4096
... MAX_LOCKDEP_ENTRIES:     16384
... MAX_LOCKDEP_CHAINS:      32768
... CHAINHASH_SIZE:          16384
 memory used by lock dependency info: 3695 kB
 per task-struct memory footprint: 1152 bytes
Calibrating delay loop... 1325.46 BogoMIPS (lpj=6627328)
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
missing device node for CPU 0
missing device node for CPU 1
Setting up static identity map for 0x496b30 - 0x496b88
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72760000, Cache size: 512 kB
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
syscon f8000000.ps7-slcr: regmap [mem 0xf8000000-0xf8000fff] registered
zynq-ocm f800c000.ps7-ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0080000
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
DMA-API: preallocated 4096 debug entries
DMA-API: debugging enabled by kernel config
Switched to clocksource arm_global_timer
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 3, 40960 bytes)
UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
bounce pool size: 64 pages
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 1470
io scheduler noop registered
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-267056
dma-pl330 f8003000.ps7-dma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3124999) is a xuartps
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to f0064000
brd: module loaded
loop: module loaded
m25p80 spi32766.0: found s25fl128s1, expected n25q128
m25p80 spi32766.0: s25fl128s1 (16384 Kbytes)
4 ofpart partitions found on MTD device spi32766.0
Creating 4 MTD partitions on "spi32766.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000001000000 : "spare"
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci-pci: EHCI PCI platform driver
zynq-dr e0002000.ps7-usb: Unable to init USB phy, missing?
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.ps7-i2c: 400 kHz mmio e0004000 irq 57
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at f006e000 with timeout 10s
zynq-edac f8006000.ps7-ddrc: ecc not enabled
cpufreq_cpu0: failed to find cpu0 node
cpufreq-cpu0: probe of cpufreq-cpu0.0 failed with error -2
Xilinx Zynq CpuIdle Driver started
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
usbhid: USB HID core driver
TCP: cubic registered
regulator-dummy: disabling
/opt/petalinux/petalinux-v2014.2-final/components/linux-kernel/xlnx-3.14/drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.63 GiB (ro)
 mmcblk0: p1
Freeing unused kernel memory: 3640K (c067d000 - c0a0b000)
INIT: version 2.88 booting
Starting Bootlog daemon: bootlogd.
Creating /dev/flash/* device nodes
random: dd urandom read with 8 bits of entropy available
starting Busybox inet Daemon: inetd... done.
Starting uWeb server:
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... xemacps e000b000.ps7-ethernet: eth0: no PHY setup
udhcpc (v1.22.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, failing
Stopping Bootlog daemon: bootlogd.
Built with PetaLinux v2014.2 (Yocto 1.6) xbpm /dev/ttyPS0
xbpm login: root
Password:
login[774]: root login on 'ttyPS0'
root@xbpm:~# dmesg
Machine model: xbpm
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat c0a50600, node_mem_map eeff8000
  Normal zone: 1520 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 194560 pages, LIFO batch:31
  HighMem zone: 528 pages used for memmap
  HighMem zone: 67584 pages, LIFO batch:15
pcpu-alloc: s10752 r8192 d13824 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Zynq clock init
Brought up 2 CPUs
vgaarb: loaded
EDAC MC: Ver: 3.0.0
PCI: CLS 0 bytes, default 64
brd: module loaded
loop: module loaded
 mmcblk0: p1
root@xbpm:
trenz-al
in subsystems/linux/configs/device-tree/system-top.dts
append
&ps7_ethernet_0 {
phy-handle = <&phy0>;
mdio {
#address-cells = <1>;
#size-cells = <0>;
phy0: phy@0 {
compatible = "marvell,88e1510";
device_type = "ethernet-phy";
reg = <0>;
change the phy as needed.
jamead
Thanks!!!!   That did the trick...
trenz-al
mark it answered then :)
jrussell
I'm having the exact same issue on a Zynq 706 board using 2014.4.  I've tried appending to system-top.dts as suggested, but get a "ps7_ethernet_0 not found" error (capture below), but ps7_ethernet_0  most certainly is described in the .hdf file from which I did the --get-hw-description.
[INFO ] build system.dtb
[ERROR] Error: /home/petaprojects/homer_kernel/subsystems/linux/configs/device-tree/system-top.dts:16.2-3 label or path, 'ps7_ethernet_0', not found
[ERROR] make[1]: *** [system.dtb] Error 255
ERROR: Failed to build linux
Thanks for any suggestions,
JR
jrussell
Never mind.  I was able to get it to work by copying a snippet from the distribution ZC706 bsp project's system-top.dts to mine.  Thanks anyway...
ringpa
I am using vivado 2014.4 (Windows 7) with Petalinux 2014.4 (CentOS 6.5) on a ZC702 eval board.  With this version of the tools, the ethernet is named "gem0".  According to the schematic, the PHY is at address 7, so I added this entry to system-top.dts:
&gem0 {
mdio {
#size-cells = <0>;
phy0: phy@7 {
compatible = "marvell,88e1116r";
reg = <7>;
It works!
gstro
Hello. I am encountering a simlar error. When I boot our custom board (using the same PHY and Enet 0 setup as the ZC702), I get the following message (full boot log attached):
Configuring network interfaces... xemacps e000b000.ethernet: eth0: no PHY found
xemacps e000b000.ethernet: XEMACPS mii bus mii_probe fail.
ifconfig: SIOCSIFFLAGS: No such device or address
I get the same message when I try to run "ifconfig eth0 up".
  • When I run "ifconfig -a", it DOES show up in the listing, complete with the static IP that I assign in the configuration.
  • It also works correctly when I emulate with petalinux-boot --qemu --kernel.
  • I have confirmed the system-top.dts shows the same ethernet node info as the ZX702 BSP project, and I'm fairly certain we copy the ethernet schematic and addresses as the the ZC702 Eval Board so the PHY addresses etc should be the same.
I'm at a loss on what to try next to troubleshoot this issue. Any help would be appreciated. Thanks.
System:
  • Windows 8 64-bit
  • VirtualBox Ubuntu 14.04 VM
  • Vivado, Xilinx SDK, PetaLinux Tools all 2014.4
  • Project created with petalinux-create -t project -n MyProj -s Xilinx-ZC702-v2014.4-final.bsp and booted with custom bitstream.
gstro
Our board's PHY was at a different address! I actually wrote a script to build 10 different projects, changing only the PHY reg address in the system-top.dts file to try to brute-force find the correct one before my colleague emailed back the details. Almost beat them to it!
For us, a change to the system-top.dts file for the &gem0 node reg was all it took:
&gem0 {
	ps7_ethernet_0_mdio: mdio {
		phy0: phy@8 {      // <== changed this from 7 to 8
			reg = <8>; // <== changed this from 7 to 8
jhonx
Hello everybody.
I had the same problem that you described when my microzed board was booting, a message appeared: "No Ethernet PHY found".
I try with solutions suchs modifying the DTS files but that didn't help me.What I did was to build the plattform using the FSBL provided by xilinx in one of its BSP (Build Suppor Package).
I hope this can help you!
gmd
I have come across this error in the past, I think you'll need to enable the particular Ethernet PHY chip support in linux.
Under kernel configuration -> Device Drivers -> Network device support ->PHY Device and Infrastructure -> Drivers for Marvell PHY (if its based on ZC702)
GMD
