medmakni
xen BOOT fail after build with petalinux 2018.2 on the ULTRA96 board
I built a Xen image with petalinux 2018.2 and xilinx-ultra96-reva-v2018.2-final.bsp following this steps:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841783/Building+Xen+Hypervisor+with+Petalinux+2018.1
After I copied the required files to my SD card partitions(BOOT.bin,xen.ub,system.dtb,image,rootfs.cpio.gz.u-boot to BOOT partition and extracted the rootfs.cpio in the rootfs partition). I got NO RESPONSE AT ALL from the board. I'm stuck here for over a month, so please help me ! and thank you
jovitac
What do you mean by no response from the board? Do you atleast see fsbl run? Can you post your boot log here?
medmakni
Hi,thank you for your response.
I connected the board via UART and display ports but i see nothing in the terminal even fsbl. I didn't find the boot.log file anywhere as the boot doesn't start at all.
PS: If I copy the Image.ub and BOOT.bin into the boot partition of the SD card, It boots but It's not xen with Linux as Dom0, It's just Linux as I see nothing related to xen when I run dmesg and the /sys/hypervisor/uuid file is missing. I even tried the sd card and initramfs in the Root file system type in the petalinux configuration and then copied the files but It's the same result.
