xilinx answer 65444 - dma_to_device: dma_to_device.c:173: test_dma: Assertion `rc == size' failed
Hello, I download xilinx answer 65444 and I follow the ''Usage'' section flow of readme.txt file.
When I execute run_test.sh file, I meet problem below.
Can anyone help me to fix it?  Thank you for your advice!
I modify the transfer size value from 1024 to 8192 of run_test.sh file and it test pass when transfer size value is 1024.
I do not know what the wrong message means.
[root@localhost tests]# ./run_test.sh
Info: Number of enabled h2c channels = 1
Info: Number of enabled c2h channels = 1
Info: The PCIe DMA core is memory mapped.
Info: Running PCIe DMA memory mapped write read test
transfer size: 8192
transfer count: 1
Info: Writing to h2c channel 0 at address offset 0.
Info: Wait for current transactions to complete.
sscanf() = 1, value = 0x00002000
sscanf() = 1, value = 0x00000000
sscanf() = 1, value = 0x00000001
device = /dev/xdma0_h2c_0, address = 0x00000000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0x1e03000
read(file_fd): Success
dma_to_device: dma_to_device.c:173: test_dma: Assertion `rc == size' failed.
./scripts/dma_memory_mapped_test.sh: line 33: 4118 Aborted (core dumped) ./dma_to_device -d /dev/xdma0_h2c_${curChannel} -f data/datafile${i}_4K.bin -s $transferSize -a $addrOffset -c $transferCount
Info: Writing to h2c channel 0 at address offset 8192.
device = /dev/xdma0_h2c_0, address = 0x00002000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0x1fb0000
./scripts/dma_memory_mapped_test.sh: line 33: 4122 Aborted (core dumped) ./dma_to_device -d /dev/xdma0_h2c_${curChannel} -f data/datafile${i}_4K.bin -s $transferSize -a $addrOffset -c $transferCount
Info: Writing to h2c channel 0 at address offset 16384.
sscanf() = 1, value = 0x00004000
device = /dev/xdma0_h2c_0, address = 0x00004000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0xcbf000
./scripts/dma_memory_mapped_test.sh: line 33: 4125 Aborted (core dumped) ./dma_to_device -d /dev/xdma0_h2c_${curChannel} -f data/datafile${i}_4K.bin -s $transferSize -a $addrOffset -c $transferCount
Info: Writing to h2c channel 0 at address offset 24576.
sscanf() = 1, value = 0x00006000
device = /dev/xdma0_h2c_0, address = 0x00006000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0xab5000
./scripts/dma_memory_mapped_test.sh: line 33: 4127 Aborted (core dumped) ./dma_to_device -d /dev/xdma0_h2c_${curChannel} -f data/datafile${i}_4K.bin -s $transferSize -a $addrOffset -c $transferCount
Info: Reading from c2h channel 0 at address offset 0.
Info: Wait for the current transactions to complete.
device = /dev/xdma0_c2h_0, address = 0x00000000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0xd44000
CLOCK_MONOTONIC reports 0.000043398 seconds (total) for last transfer of 8192 bytes
Info: Reading from c2h channel 0 at address offset 8192.
device = /dev/xdma0_c2h_0, address = 0x00002000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0x2398000
CLOCK_MONOTONIC reports 0.000049757 seconds (total) for last transfer of 8192 bytes
Info: Reading from c2h channel 0 at address offset 16384.
device = /dev/xdma0_c2h_0, address = 0x00004000, size = 0x00002000, offset = 0x00000000, count = 1
host memory buffer = 0x1c62000
Thank!
because dma_to_device read data from data/datafile0_4K.bin which is only 4096 bytes
you should use a larger file instead
Hi eddylee:
I did same test as yours but my situation even worse.
After run_test.sh runs, it hangs over there.
I can not see: CLOCK_MONOTONIC reports 0.000049757 seconds (total) for last transfer of 8192 bytes.
Do you have any suggestions?
Frank
I get the same error when i do ./dma_to_device from command prompt. I am transfering h2c 10bytes here. But even that gets stuck. C2h is also stuck. Pls suggest!!!
