xilinx_drm_dri: what is it, where to find it, how to enable it ?
Hi, guys
I'm facing a problem, My application (some camera app, called ZED Explorer by stereolabs) runs with Xorg reports a issue:
libGL error: unable to load driver :xilinx_drm_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver xilinx_drm
The application still runs, just don't have a high performance. As you may wonder, my desktop GUI also have extremely low performance.
I figured may be the xilinx_drm issue is the root cause.
The thread 849308 suggests to include Xilinx_DRM in kernel config, which I already done. The issue remains.
@imgignaciomentioned in the thread that the driver is a built-in module.
But seems even it is built-in, some application still cannot find it.
I searched through the generated rootfs by petalinux, there also isn't a xilinx_drm_dri.so available.
I use a non-xilinx-provided ubuntu 16.04 rootfs for arm64 which of course don't have xilinx's user space libs, as xilinx don't provide ubuntu 16.04 rootfs.
I wonder if the running rootfs should be configured with any petalinux compiled library to make it work with xilinx_drm and improve performance
Any suggestions?
Thanks!
Kang
Tags (4)
