Visitor mrzhang_
xinit: Unable to run program "xterm": No such file or directory
HI
when i use this command run_video.sh , i see these error. Who can help me?
Thanks!
** Zynq UltraScale+ MPSoC Base TRD Qt Application **
Starting application...
hostname: zcu102_base_trd: Unknown host
xauth:  file /home/root/.serverauth.2382 does not exist
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-573.el6.x86_64 x86_64
Current Operating System: Linux zcu102_base_trd 4.9.0 #8 SMP Fri Dec 1 11:30:36 CST 2017 aarch64
Kernel command line: earlycon clk_ignore_unused earlyprintk uio_pdrv_genirq.of_id=xlnx,generic-uio cma=1024M
Build Date: 19 June 2017  09:37:47PM
Current version of pixman: 0.34.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.3.log", Time: Fri Dec  1 09:32:09 2017
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Specify a program on the command line or make sure that /usr/bin
is in your path.
xinit: connection to X server lost
waiting for X server to shut down X: ../../xorg-server-1.18.4/include/privates.h:122: dixGetPrivateAddr: Assertion `key->initialized' failed.
