yocto or petalinux
Hello everyone,
I will start a project which is based on Linux and my platform is Zedboard. I couldn't decide whether to use petalinux or yocto. I have used yocto on different platforms before and had no problems. But ı don't know anything about Petalinux. Also this project based QT.
What's the advantages of petalinux or yocto? Which one is easier for initial setup and bring-up QT
hi @aforizma1842
Petalinux is built on Yocto and more easy to use, you can basically build a system with several commands. And you should have no problem in getting familiar with Petalinux since you already had Yocto experience.
hi @aforizma1842
Hi @aforizma1842
I suggest you to use petalinux.
Because you can build qemu based QT toolkit by "petalinux-build --sdk" command.
It's easy to prepare what you want to do.
Best regards,
