dpekin
zc702 Linux boot hang whie "Calibrating delay loop..."
Hi All,
I have downloaded the latest Linux sources and tools (2011.09-50).  I built the default Linux kernel per the Wiki.
When the zynq development board the boots, it hangs when it is "Calibrating delay looop..."  Below is the boot trace.
Comparing with the good kernel boot trace (attached further down), I see the Virtual kernel memory layout is different.
Any suggestions on what might be going on is appreciated.
- Dave
Xilinx First Stage Boot Loader
INFO : Configure FPGA
........................................................................................................................................................................................................................................................ DONE!
INFO : Initialize PS I2C0
INFO : Initialize HDMI OUT
WARNING : No monitor detected on HDMI OUT
INFO : Initialize PS I2C1
INFO : Initialize PS GPIO
INFO : No FMC card detected on FMC2
U-Boot 2010.09-01937-g08bd7a6 (May 15 2012 - 11:33:17)
DRAM: 256 MiB
## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
Flash: 0 Bytes
MMC: SDHCI: 0
Using default environment
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 3  2  1  0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 1.10
High Capacity: Yes
Capacity: 7948206080
Bus Width: 1-bit
reading zImage
2406640 bytes read
reading devicetree.dtb
7908 bytes read
reading ramdisk8M.image.gz
2504235 bytes read
## Starting application at 0x00008000 ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0-14.2-build1-01466-g1e92da8 (notroot@ubuntu) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #1 SMP PREEMPT Wed Jul 25 19:55:24 UTC 2012
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c16cb000 s5696 r8192 d14784 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190784
Kernel command line: console=tty0 console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M ip=192.168.1.10:::255.255.255.0:ZC702:eth0 earlyprintk mem=768M memmap=128M$0x30000000 vmalloc=256M
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 240MB 512MB = 752MB total
Memory: 749444k/749444k available, 36988k reserved, 16384K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xef800000 - 0xff000000 ( 248 MB)
lowmem : 0xc0000000 - 0xef000000 ( 752 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc040ad7c (4108 kB)
.init : 0xc040b000 - 0xc042f640 ( 146 kB)
.data : 0xc0430000 - 0xc045dda0 ( 184 kB)
.bss : 0xc045ddc4 - 0xc047801c ( 105 kB)
Verbose stalled-CPUs detection is disabled.
NR_IRQS:128
------------[ cut here ]------------
WARNING: at arch/arm/mach-zynq/timer.c:299 xttcpss_timer_init+0x64/0x248()
Modules linked in:
[<c0012928>] (unwind_backtrace+0x0/0xe0) from [<c001e84c>] (warn_slowpath_common+0x4c/0x64)
[<c001e84c>] (warn_slowpath_common+0x4c/0x64) from [<c001e87c>] (warn_slowpath_null+0x18/0x1c)
[<c001e87c>] (warn_slowpath_null+0x18/0x1c) from [<c0411f60>] (xttcpss_timer_init+0x64/0x248)
[<c0411f60>] (xttcpss_timer_init+0x64/0x248) from [<c040eb38>] (time_init+0x20/0x2c)
[<c040eb38>] (time_init+0x20/0x2c) from [<c040b66c>] (start_kernel+0x1a0/0x304)
[<c040b66c>] (start_kernel+0x1a0/0x304) from [<00008044>] (0x8044)
---[ end trace 1b75b31a2719ed1c ]---
xlnx,ps7-ttc-1.00.a #0 at 0xef800000, irq=0
console [tty0] enabled
************   FOLLOWING IS THE BOOT TRACE FROM THE GOOD KERNEL  *************
DRAM: 256 MiB
Flash: 0 Bytes
MMC: SDHCI: 0
In: serial
Out: serial
Err: serial
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 1.10
High Capacity: Yes
Bus Width: 1-bit
reading zImage
2323216 bytes read
7908 bytes read
2504235 bytes read
Linux version 3.0.0-14.1-build3-01350-gffde6d9 (ckohn@xsjmarkbrolx) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #7 SMP PREEMPT Thu May 24 17:16:04 PDT 2012
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
PERCPU: Embedded 7 pages/cpu @c160a000 s4928 r8192 d15552 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190976
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 750964k/750964k available, 35468k reserved, 524288K highmem
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xd0800000 - 0xe0000000 ( 248 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
.init : 0xc0008000 - 0xc002c000 ( 144 kB)
.text : 0xc002c000 - 0xc040cfc4 (3972 kB)
.data : 0xc040e000 - 0xc04384c0 ( 170 kB)
.bss : 0xc04384e4 - 0xc045178c ( 101 kB)
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xd0800000, irq=43
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 512
Calibrating local timer... 333.43MHz.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
devtmpfs: initialized
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72060000, Cache size: 524288 B
registering platform device 'pl330' id 0
registering platform device 'arm-pmu' id 0
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
xslcr xslcr.0: at 0xF8000000 mapped to 0xD0808000
bio: create slab <bio-0> at 0
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xd080a000
Xilinx DMA driver
xilinx-dma 40090000.axivdma: Probing xilinx axi dma engines
xilinx-dma 400b0000.axivdma: Probing xilinx axi dma engines
SCSI subsystem initialized
Switching to clocksource xttcpss_timer1
IP route cache hash table entries: 8192 (order: 3, 32768 bytes)
TCP established hash table entries: 32768 (order: 6, 262144 bytes)
TCP bind hash table entries: 32768 (order: 6, 393216 bytes)
TCP: Hash tables configured (established 32768 bind 32768)
TCP reno registered
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 8192K
PMU: registered new PMU device of type 0
xscugtimer xscugtimer.0: ioremap f8f00200 to d080c200 with size 400
pl330 dev 0 probe success
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 458
io scheduler noop registered
xvdma xvdma.0: Xilinx VDMA probe successful
Devices Scanned 2
e00ܽ¹Í½±•[ttyPS0] enabled, bootconsole disabled
console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to d081e000 with size 1000
brd: module loaded
loop: module loaded
m25p80 spi1.0: n25q128 (16384 Kbytes)
Creating 7 MTD partitions on "serial_flash":
0x000000000000-0x000000080000 : "qspi-fsbl"
0x000000080000-0x000000100000 : "qspi-u-boot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000700000 : "qspi-user"
0x000000700000-0x000000800000 : "qspi-scratch"
0x000000800000-0x000001000000 : "qspi-rootfs"
xqspips e000d000.spi: at 0xE000D000 mapped to 0xD0832000, irq=51
GEM: BASEADDRESS hw: e000b000 virt: d0834000
XEMACPS mii bus: probed
xemacps e000b000.eth: invalid address, use assigned
MAC updated de:95:19:44:89:46
eth0, pdev->id -1, baseaddr 0xe000b000, irq 54
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
Xilinx PS USB Device Controller driver (Apr 01, 2011)
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
xi2cps e0004000.i2c: 100 kHz mmio e0004000 irq 57
si570 1-005d: registered si570 with default frequency 156250000 Hz
si570 1-005d: set initial output frequency 148500000 Hz
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: chip found, driver version 0.4.3
rtc-pcf8563 5-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 5-0051: retrieved date/time is not valid.
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
Linux video capture interface: v2.00
gspca: v2.13.0 registered
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
WDT OF probe
xwdtps f8005000.swdt: Xilinx Watchdog Timer at 0xd083a000 with timeout 10 seconds
mmc0: Invalid maximum block size, assuming 512 bytes
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
usbhid: USB HID core driver
TCP cubic registered
Console: switching to colour frame buffer device 240x67
xylonfb 0 registered
mmc0: new SDHC card at address e624
xylonfb 1 registered
xylonfb 2 registered
mmcblk0: mmc0:e624 SU08G 7.40 GiB
mmcblk0: p1
si570 1-005d: set new output frequency 148500000 Hz
xylonfb video mode: 1920x1080-16bpp@60
rtc-pcf8563 5-0051: hctosys: invalid date/time
GEM: lp->tx_bd ffdfb000 lp->tx_bd_dma 0e998000 lp->tx_skb ce8d0be0
GEM: lp->rx_bd ffdfc000 lp->rx_bd_dma 0e8df000 lp->rx_skb ce8d0ae0
GEM: MAC 0x441995de, 0x00004689, de:95:19:44:89:46
GEM: phydev ce958800, phydev->phy_id 0x1410e40, phydev->addr 0x7
eth0, phy_addr 0x7, phy_id 0x01410e40
eth0, attach [Marvell 88E1116R] phy driver
IP-Config: Complete:
device=eth0, addr=192.168.1.10, mask=255.255.255.0, gw=255.255.255.255,
host=ZC702, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
RAMDISK: gzip image found at block 0
EXT2-fs (ram0): warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Starting rcS...
++ Mounting filesystem
++ Setting up mdev
++ Starting telnet daemon
++ Starting http daemon
++ Starting ftp daemon
++ Starting dropbear (ssh) daemon
++ Mounting SD Card at /mnt
rcS Complete
zynq> eth0: link up (1000/FULL)
dpekin
Thanks for your rapid support!
I compiled the zynq-zc702.dts file per wiki instructions, copied it to the SD card and now Linux 3.3 is happy booting on the dev board.
Now for the real work - tayloring the kernel to our needs.
Another question on the dts/dtb file.  If I remove a driver from the kernel that is specified in the DTS file, I need to remove that driver's entry in the DTS file, right?
Thanks again!
- Dave
norman_wong
I'm guessing you need a device tree to match your kernel. Use the dts file in your kernel source.
dpekin
I thought that doing the "make ARCH=arm xilinx_zynq_defconfig"  per the Wiki would configure the kernel for the Zynq 702 board.  Is this not correct?
- Dave
linnj
You switched kernel versions, 3.0 to 3.3, and as he said you need a new device tree binary.
The kernel page (a bit buried) tried to describe this.
For Linux kernel 3.3 and later, the device tree syntax has changed for denoting interrupts. To calculate the correct value in these releases, use Table 7-3 in the Zynq-7000 EPP TRM to locate the correct SPI ID# for the desired peripheral. Then, subtract 32 from this value. The result is what should be entered into the device tree interrupt field.
dpekin
Thanks again!
- Dave
linnj
Great! Glad to hear that.
The device tree can have entries for which there is no kernel driver. If there's no driver, there's no code to run so it should not be an issue.
ingdb
I also tried to compile the kernel and the device tree as described on the zynq wiki page. My linux kernel is running but when starting the Zynq TRD application I got the following error message (and no signal on the monitor):
QScreenLinuxFb::connect: No such file or directory
Error opening framebuffer device /dev/fb0
The linux boot messages (see below) seems to be sensible.
Any ideas?
Best regards,
Matthias
INFO : Avnet FMC-IMAGEON detected on FMC2
INFO : Initialize HDMI IN
DRAM: 256 MiB
Flash: 0 Bytes
MMC: SDHCI: 0
In: serial
Out: serial
Err: serial
Device: SDHCI
Manufacturer ID: 1
OEM: 5041
Rd Block Len: 512
SD version 1.10
High Capacity: No
Capacity: 2014838784
Bus Width: 1-bit
reading zImage
2303144 bytes read
4048 bytes read
2504235 bytes read
Linux version 3.3.0-14.2-build1-01491-g42fac65-dirty (matthias@matthias-MS-7646) (gcc version 4.6.1 (Ubuntu/Linaro 4.6.1-9ubuntu3) ) #4 SMP PREEMPT Sun Aug 19 16:42:02 CEST 2012
PERCPU: Embedded 7 pages/cpu @c16c9000 s5696 r8192 d14784 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 194880
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M ip=192.168.1.10:::255.255.255.0:ZC702:eth0:dhcp earlyprintk mem=768M memmap=128M$0x30000000 vmalloc=256M
Memory: 768MB = 768MB total
Memory: 765816k/765816k available, 20616k reserved, 16384K highmem
.text : 0xc0008000 - 0xc040e398 (4121 kB)
.init : 0xc040f000 - 0xc0434640 ( 150 kB)
.data : 0xc0436000 - 0xc0463d20 ( 184 kB)
.bss : 0xc0463d44 - 0xc047df5c ( 105 kB)
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xef800000, irq=43
smp_twd: clock not found: -2
Calibrating local timer... 333.58MHz.
Setting up static identity map for 0x2f7978 - 0x2f79ac
Brought up 2 CPUs
MIO pin 47 not assigned(00001220)
xslcr xslcr.0: at 0xF8000000 mapped to 0xEF808000
gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xef80a000
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
xscugtimer xscugtimer.0: ioremap fe00c200 to ef80c200 with size 400
msgmni has been set to 1479
e007œ¹Íœ±•[ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to ef860000 with size 100
brd: module loaded
loop: module loaded
7 ofpart partitions found on MTD device spi1.0
Creating 7 MTD partitions on "spi1.0":
xqspips e000d000.spi: at 0xE000D000 mapped to 0xEF862000, irq=51
GEM: BASEADDRESS hw: e000b000 virt: ef864000
MAC updated 9e:79:ec:8a:cb:92
gspca_main: v2.14.0 registered
uvcvideo: Unable to create debugfs directory
USB Video Class driver (1.1.1)
WDT OF probe
xwdtps f8005000.swdt: Xilinx Watchdog Timer at 0xef86a000 with timeout 10 seconds
GEM: lp->tx_bd ffdfb000 lp->tx_bd_dma 2e997000 lp->tx_skb eebed400
GEM: lp->rx_bd ffdfc000 lp->rx_bd_dma 2e996000 lp->rx_skb eebed000
GEM: MAC 0x8aec799e, 0x000092cb, 9e:79:ec:8a:cb:92
usb 1-1: new full-speed USB device number 2 using xusbps-ehci
GEM: phydev ee2eba00, phydev->phy_id 0x1410e40, phydev->addr 0x7
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
mmc0: new SD card at address c087
mmcblk0: mmc0:c087 SM02G 1.87 GiB
mmcblk0: p1
devtmpfs: mounted
Freeing init memory: 148K
Starting rcS...
++ Setting up mdev
usb 1-1.1: new low-speed USB device number 3 using xusbps-ehci
input: HID 0566:3032 as /devices/amba.0/e0002000.usb/xusbps-ehci.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
generic-usb 0003:0566:3032.0001: input: USB HID v1.11 Keyboard [HID 0566:3032] on usb-xusbps-ehci.0-1.1/input0
input: HID 0566:3032 as /devices/amba.0/e0002000.usb/xusbps-ehci.0/usb1/1-1/1-1.1/1-1.1:1.1/input/input1
generic-usb 0003:0566:3032.0002: input: USB HID v1.11 Device [HID 0566:3032] on usb-xusbps-ehci.0-1.1/input1
++ Running user script init.sh from SD Card
Starting Zynq Base TRD Application...
usb 1-1.2: new low-speed USB device number 4 using xusbps-ehci
input: HID 04d9:0499 as /devices/amba.0/e0002000.usb/xusbps-ehci.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
generic-usb 0003:04D9:0499.0003: input: USB HID v1.10 Mouse [HID 04d9:0499] on usb-xusbps-ehci.0-1.2/input0
ckohn
Hi Matthias and Dave,
the problem is that you are trying to run the 14.1 Base TRD on a 3.3 linux kernel. The 14.1 Base TRD release requires a specific linux kernel commit which is based on a 3.0 kernel tagged xilinx-14.1-build3-trd. On top of that you need to apply a patch (delivered with the Base TRD) which will give you a modified kernel config file and devicetree to work with the underlying hardware. Please make sure you follow the instructions on our Base TRD wiki page - step 7 in specific: http://wiki.xilinx.com/zynq-base-trd-14-1
The 14.2 Base TRD update will be based on the 3.3 linux kernel. The corresponding linux kernel and u-boot tags are already pushed out but the 14.2 Base TRD package hasn't made it on our website yet. Please wait for the 14.2 update if you want to use the 3.3 kernel. It will come with a corresponding kernel patch to match the config, devicetree and hardware changes of the 14.2 update/3.3 kernel.
Chris
oyvind
Hello Chris,
any idea when the TRD 14.2 package will be available for download?
Øyvind
ckohn
Hi Oyvind,
I don't have an exact date but the new package should be online by the end of this week. I will post in the forum once it's available.
Chris
ckappler
I'm running into this inifite loop as well after boot:
Any you are right that a 3.3 kernel is being used in the ug873-deisgn-files.zip that is linked on the web site with the 14.1 TRD.  I tried building my own kernel in order to follow along with chapter 5 of the Concepts Tools and Techniques tutorial.
  http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/ug873_zynq_ctt.pdf
However, that 3.0 kernel that I built paniced because it couldnt' find the debug circuitry where it expected it.  Is there a 14.1 version of ug873-design-files.zip somewhere that I can download?
ckohn
Please look at my first post in this thread.
If you are trying to run the 14.1 TRD, you have to follow the instructions on the TRD wiki on how to build the kernel. It requires you to pull a specific kernel tag from our git tree and then apply a patch against that kernel. You also need to use a specific devicetree that has the framebuffer driver instantiated. Both the patch and the devicetree are part of the 14.1 TRD package.
Hope this helps.
