dpekin
zc702 QSPI Flash Options 16 or 32 MB?
The 16MB QSPI Flash on the zc702 dev board is a bit small for our application.  We would like to have 32MB of contiguous QSPI flash.
This is a line from AR#50991  "Currently QPSI is only supported up to 16MB in single mode or 32 MB in dual mode due to limitations in the linear controller."   (http://www.xilinx.com/support/answers/50991.htm)
Has anyone implemented a 32MB "dual mode" QSPI flash?  Does it work with the current (3.3) QSPI drivers?  If so, what QSPI chip did you use.
Thanks in advance.
- Dave
karlk
Dave,
You can use two QSPI devices in parallel. We have tested this with the Spansion S25FL128 parts and the Micron N25Q128A parts.
The latest UBoot builds have support for the Micron N25Q128A 3.3v parts - I am not sure about Linux support.
dpekin
Thanks. Anyone know about the QSPI driver support?
linnj
Hi Dave,
The ZC706 does us a dual QSPI design so there is 32 MB of QSPI. I don't like some aspects of that design much as it's somewhat non-std in Linux such that higher MTD layers and other stuff had to be hammered to make it work as it looks like a single device that is twice as big to Linux. Linux does work on that board with the 32 MB of QSPI.
There is some bigger single device support being worked on I believe but it's early to know all the details there.
dpekin
Thanks John,
You say 32MB dual mode QSPI works on the ZC706.  Is that applicable to the ZC702?
-Dave
linnj
Hi Dave,
Sorry for the slow response. It's not applicable to the ZC702 as it only has a single device on it.
smazzux
Hi to everybody.
I just wanted to revive this thread a bit and ask if there is any news about the support for 32 MB QSPI flash in Linux for Zynq.
I am mostly interested in a single chip solution for pin and space saving, so I know that linear adressing is not applicable.
It seems there is some work in progress but nothing recent shows up when digging in the forums.
http://www.zedboard.org/content/access-upper-16-mb-qspi-flash#comment-3235
Many thanks and best regards,
Giulio
milosoftware
With the latest kernel, the 32MB of the zedboard "just works" now. The driver uses bank switching to go from the lower to the up 16MB of the chip on the zedboard. I noticed the flash chip of the zed is much faster than the one on the zc702 too.
I've been running a UBI root filesystem on it for about a month or so.
smazzux
Thank you milo for the feedback. That's great news!
I'll investigate the driver shipped there for reference.
Furthemore it seems that by enabling compression for the bitstream is possible to save a few extra megabytes (if the FPGA is not fully loaded) to be able to fit a petalinux system for production even on a 16 MB qspi flash.
Giulio
milosoftware
I store the FPGA bitstream in the rootfs.
The bitstream file is just over 4MB, but only occupies about 500k of actual flash memory thanks to ubifs compression (lzo).
The bitstream contains ADI's design for HDMI and audio, plus a bunch of things we're working on in the project.
Because the flash media is relatively slow and the CPU is fast enough, storing the bitstream in a compressed format effectively speeds up the boot sequence.
salizaidi
Hello EveryOne,
My understanding of ZC702 kit was that it has 16MB addressable memory(becuase of 3-byte addressing) but we can enable more memory on the same device by using extendable memory register making it 4-byte addressing hence greater than 16 MB.Kindly let me know if i am mistaking.
Thankyou.
