imadmed@fp
zc702 ethernet does not work, ADV7511 Reference Design, Linaro ubuntu Desktop
I used the ADV7511 Reference Design on zc702 with linaro ubuntu desktop,
the connection icon is invisible. in addition, when I tried to check the connection parameters, this message appears "system network services not compatible with this version"
ps1: however ping can send via termianal
ps2: I used vaivado 14.4.1
sandeepg
Hi imadmed@fp,
We don't support Ubuntu rootfs refer our support policy http://www.wiki.xilinx.com/Embedded+SW+Support
Sandeep
imadmed@fp
thank you for your reply
I revised some post on this forum, and I understood that the problem can be of origin of devicetree
do you have any suggestions that can guide me to solve this problem?
