zc702 xapp794 mount: mounting /dev/mmcblk0p1 on /mnt failed: No such file or directory
I have put the serial terminal log below. No further experience about the linux. Any advise please?
I looked at mnt folder is seen by typing -ls command. However mnt folder is empty. Is this normal?
The correct terminal log should be same as shown Xapp794, page 14-16.
U-Boot 2011.03 (Jul 12 2012 - 09:03:13)
DRAM: 256 MiB
MMC: SDHCI: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: zynq_gem
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 1.10
High Capacity: Yes
Capacity: 7948206080
Bus Width: 1-bit
reading zImage
2399280 bytes read
reading devicetree.dtb
3972 bytes read
reading ramdisk8M.image.gz
2498905 bytes read
## Starting application at 0x00008000 ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0-14.2-build1-01464-ged63a4d (elzinga@xcoapps53) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #2 SMP PREEMPT Mon Jul 23 16:41:03 MDT 2012
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c190b000 s5696 r8192 d14784 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 255744
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M i p=:::::eth0:dhcp earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 240MB 768MB = 1008MB total
Memory: 1009296k/1009296k available, 39280k reserved, 270336K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0408c34 (4100 kB)
.init : 0xc0409000 - 0xc042c640 ( 142 kB)
.data : 0xc042e000 - 0xc045bba0 ( 183 kB)
.bss : 0xc045bbc4 - 0xc0475e10 ( 105 kB)
Verbose stalled-CPUs detection is disabled.
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xf0000000, irq=43
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 512
smp_twd: clock not found: -2
Calibrating local timer... 333.56MHz.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x2f1188 - 0x2f11bc
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
devtmpfs: initialized
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
registering platform device 'pl330' id 0
registering platform device 'arm-pmu' id 0
MIO pin 47 not assigned(00001220)
xslcr xslcr.0: at 0xF8000000 mapped to 0xF0008000
bio: create slab <bio-0> at 0
gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xf000a000
SCSI subsystem initialized
Switching to clocksource xttcpss_timer1
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 8192K
xscugtimer xscugtimer.0: ioremap fe00c200 to f000c200 with size 400
pl330 dev 0 probe success
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 1459
io scheduler noop registered
e007½¹Í½±•[ttyPS0] enabled, bootconsole disabled
console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to f0060000 with size 100
brd: module loaded
loop: module loaded
m25p80 spi1.0: n25q128 (16384 Kbytes)
7 ofpart partitions found on MTD device spi1.0
Creating 7 MTD partitions on "spi1.0":
0x000000000000-0x000000080000 : "qspi-fsbl"
0x000000080000-0x000000100000 : "qspi-u-boot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000700000 : "qspi-user"
0x000000700000-0x000000800000 : "qspi-scratch"
0x000000800000-0x000001000000 : "qspi-rootfs"
xqspips e000d000.spi: at 0xE000D000 mapped to 0xF0062000, irq=51
GEM: BASEADDRESS hw: e000b000 virt: f0064000
XEMACPS mii bus: probed
eth0, pdev->id -1, baseaddr 0xe000b000, irq 54
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
Xilinx PS USB Device Controller driver (Apr 01, 2011)
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
xi2cps e0004000.i2c: 100 kHz mmio e0004000 irq 57
si570 1-005d: registered si570 with default frequency 156250000 Hz
si570 1-005d: set initial output frequency 148500000 Hz
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: chip found, driver version 0.4.3
rtc-pcf8563 5-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 5-0051: retrieved date/time is not valid.
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
Linux video capture interface: v2.00
gspca_main: v2.14.0 registered
uvcvideo: Unable to create debugfs directory
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
WDT OF probe
xwdtps f8005000.swdt: Xilinx Watchdog Timer at 0xf006a000 with timeout 10 second s
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
usbhid: USB HID core driver
TCP cubic registered
rtc-pcf8563 5-0051: hctosys: invalid date/time
RAMDISK: gzip image found at block 0
mmc0: new SDHC card at address e624
mmcblk0: mmc0:e624 SD08G 7.40 GiB
mmcblk0:
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing init memory: 140K
Starting rcS...
++ Mounting filesystem
++ Setting up mdev
++ Mounting SD card to /mnt
++ Configuring IP Address
/etc/init.d/rcS: line 24: /mnt/config_my_ip.sh: not found
++ Starting telnet daemon
++ Starting http daemon
httpd: chdir(/mnt/www): No such file or directory
++ Starting ftp daemon
++ Starting dropbear (ssh) daemon
rcS Complete
/etc/init.d/rcS: line 41: /mnt/launch_my_app.sh: not found
zynq> ls
README     licenses          proc     update_qspi.sh
bin               linuxrc             root      usr
dev              lost+found       sbin     var
etc              mnt                  sys
lib               opt                   tmp
zynq> cd mnt
zynq> ls
zynq> ls
zynq>
Tags (4)
Re: zc702 xapp794 mount: mounting /dev/mmcblk0p1 on /mnt failed: No such file or directory
Looks like your SD card doesn't have the first partition. Can you confirm if /dev/mmcblk0p1 exists.
If not  Prepare the SD card. Use SD formatter tool to create a FAT partition, https://www.sdcard.org/downloads/formatter_4/ and copy the XAPP images again and retry the boot.
Hope it helps.
Radhey
Hope it helps.
Radhey
Hello @radheys
There is no /dev/mmcblk0p1 . I did not know that I should format the SD car via such an SD_CardFormatter before putting Xapp794 boot files inside it.  I downloaded the SD_CardFormatter and I formatted the SD card. App note is seen works properly.
Thank you,
Tags (3)
