zc706 U-Boot dhcp doesn't work
Hello!
I have a zc706 board. I built my image(s) using yocto (rocko branch) and was able to successfully boot the board to Linux without issue. Now I want to be able to do a network boot using DHCP from u-boot but am not able to get that to work. Immediately after the BOOTP broadcast message I get a "data abort" error displayed. It looks like u-boot has the network and DHCP configured but I keep getting the "data abort" error.
Any ideas about what is going wrong and how to fix it?
Re: zc706 U-Boot dhcp doesn't work
I rolled back to the pyro branch and u-boot is fully functional. So the rocko branch u-boot has an issue. I will stick to pyro since you indicated that rocko is not yet verified and validated
Hi Neil
Are you able to ping from u-boot?
Best Regards
Shabbir
Yes. ping appears to work.
I just tried ping again. If I set a static ip address (which it appears to require) for the zc706 then I get the same 'crash' with the data abort message. Without the static IP it complains that ipaddr is not set
Hi Neil
Did you configure the petalinux to select static IP? You can do something like this
petalinux-config ---> u-boot Configuration->TFTP Server IP address ---> Specify static IP address
or
alternatively, if you are nou using petalinux flow, then you can define this macro in u-boot configuration file
For example, #define CONFIG_SERVERIP 192.168.42.3
Best Regards
Shabbir
I am using yocto. I can try that server IP config. But seeing as these are all environment variables settable at run time, why would this fix it when setting these variables at run time has no beneficial effect?
Hi neil@formidableengineeringconsultants.com,
Rocko release is based on 4.14 kernel which is not public which should be available in 3 weeks.
When you use Rocko with 4.9 kernel we haven't validated from Xilinx engineering team and that is not our supported flow. The results could be unpredictable.
Sandeep
Thanks Sandeep. I think the issue is in u-boot and not the kernel. So there may be a problem in the rocko flavor of u-boot. I will try rolling back to an earlier branch. I don't have a compelling reason to use rocko except that it's new :-)
