atower
zc706 led blink example?
HI, all
my board is zc706, SDK2015.4.  there are four user leds on the board, and I want to blink one of it.
I use the source file SDK/2015.4/data/embeddedsw/XilinxProcessorIPLib/drivers/gpio_v4_0/examples/xgpio_example.c, and build a standalone project include xgpio_example.c and other files. but when I compile it , there is an error:
error: 'XPAR_LEDS_POSITIONS_DEVICE_ID' undeclared (first use in this function)
 #define GPIO_EXAMPLE_DEVICE_ID  XPAR_LEDS_POSITIONS_DEVICE_ID
I search the whole SDK directory, unfortunately, can't find any define about XPAR_LEDS_POSITIONS_DEVICE_ID.
who can help me please ?
Tom
muzaffer
@atower I haven't done this myself in quite a while but I think these headers come through the HDF file you generate when you implement your design with the LEDs in them (or the GPIO driving LEDs). You push the HDF file through the sdk to generate the BSP and the application and the BSP has the necessary hardware dependent headers in it one of which is the file with the definition you need.
balkris
check this example
https://www.youtube.com/watch?v=8i8GLF-Md3U
all LEDs on the zc706 are connected to PL pins. So, at a bare minimum, you need a bitstream that routes those pins to the PS GPIO on the EMIO interface.
Once there you should use the gpio-led driver to control the LEDs.
http://forums.xilinx.com/t5/Embedded-Linux/Blink-LEDs-in-Linux-on-Zynq-through-dev-mem/m-p/534365/highlight/true#M10996
http://www.wiki.xilinx.com/Linux+GPIO+Driver#Linux%20Kernel%20Drivers-LEDS-GPIO%20Driver
For board debug you can refer this ARs
https://www.xilinx.com/support/answers/54013.html
Please check if below discussion helps
http://forums.xilinx.com/t5/Embedded-Linux/How-do-I-access-GPIO-on-ZedBoard-using-the-latest-Petalinux/td-p/365741
Also this AR
http://www.xilinx.com/support/answers/51786.html
Thanks and Regards
Balkrishan
achutha
@atower
"XPAR_LEDS_POSITIONS_DEVICE_ID" in xgpio_example.c a reference and you have to change the name based on the hardware instances that were created.
Example:
#define GPIO_EXAMPLE_DEVICE_ID XPAR_AXI_GPIO_0_DEVICE_ID
Refer to the xparameters.h file located in the BSP generated (ex:project_1.sdk\standalone_bsp_0\ps7_cortexa9_0\include) for device_ID of your GPIO peripheral.
Achutha
atower
Hi,Achutha
thanks for your reply.
I searched the file xparameters.h, it jut define the two below:
/* Definitions for peripheral PS7_GPIO_0 */
#define XPAR_PS7_GPIO_0_DEVICE_ID 0
#define XPAR_PS7_GPIO_0_BASEADDR 0xE000A000
but in the gpio example, it need the fefine these as below:
#define GPIO_REG_BASEADDR    XPAR_LEDS_POSITIONS_BASEADDR
so can I define them by myself in my application as below:
#define      XPAR_LEDS_POSITIONS_BASEADDR      XPAR_PS7_GPIO_0_BASEADDR
#define      XPAR_LEDS_POSITIONS_DEVICE_ID      XPAR_PS7_GPIO_0_DEVICE_ID
Tom
