[zcu104]Auto resize ext4 partitions
I ran the attached file to resize ext4 partition, but it was useless.
How can I do?
PS. the script is from https://github.com/Xilinx/Vitis-AI/blob/master/DPU-TRD/app/dpu_sw_optimize.tar.gz
Sitting
Hi @sitting
Would you try to add "ext4_resize" at last line and run this modified script file ?
Best regards,
Hi @sitting
Best regards,
Hi @watari
I have tried your recommendation, the script works now.
Thank you so much
Sitting
