zcu106 vcu trd DM1 petalinux not build
system-top.dtb :ERROR duplicate label ‘vcu_0’
Re: zcu106 vcu trd DM1 petalinux not build
HI @v3best,
Are you still experiencing the issue? Could you share the all the steps use and your full log (attach to the topic in a TXT format).
Florent
