freeliver
zedboard USB host not work in petalinux2014.2 prebuild
hi, my zedboard(rev.D)  USB host can work well in the zedboad OOB Design. But I try the Avnet-Digilent-ZedBoard-v2014.2-final.bsp  prebuild in petalinux2014.2 ,the USB HOST cann't work. It can not supply the power to the mouse.
I see  usb host not working in the forums, but it can't solve my problem. I checked the config ,it has been : Device Drivers->USB Support->USB Physical Layer Drivers-->Xilinx Zynq USB OTG dual-role support .
if anyone faced the same problem?
freeliver
I changed the  DTS file, and the mouse is ok.
freeliver
This is my config file in the project/config/linux/configs/kernel/config . I try the prebuild file in the the Avnet-Digilent-ZedBoard-2013.3.bsp, it cann't support the usb mouse.why?
freeliver
dpekin
How did you change the DTS file?
We're trying to bring up a host USB using USBController 1 at 0xe0003000 and have so far been unsuccessful..
Our custom hardware is close to the ZC702 Dev board but since we have 2 Ethernet ports, we need to use the 2nd USB controller since the 2nd ethernet port uses the same MIO lines as the first USB.
Thanks for any suggestions.
- Dave
