Visitor sinai
zedboard does not mount other usb devices only a pendrive fat32 using petalinux 2017.3
After configuring and adding all the USB functions (otg, host and peripheral) in the kernel and device tree. the petalinux recognizes only the USB host (pen driver) but when I plug in a modem, webcam, sensor, etc it does display that a device has been plugged but there is no way to mount or see it in /dev/sdbx. if I do lsusb I  can see the bus information.
- So how can I read and write on other devices?
- Any suggestion on how to access the gpio just in case the usb does not work forever
I added in the kernel all the functions by following these links
1) https://medium.com/developments-and-implementations-on-zynq-7000-ap/interfacing-a-usb-webcam-and-enable-usb-tethering-on-zynq-7000-ap-soc-running-linux-1ba6d836749d
2)https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842272/Zynq+Linux+USB+Device+Driver
Scholar watari
Re: zedboard does not mount other usb devices only a pendrive fat32 using petalinux 2017.3
Hi @sinai
The "/dev/sdbx" is only for mount point of storage.
So, you can not find like it hen you plug in a modem, webcam, sensor, and so on.
Also, these devices require each driver module. Therefore you need to prepare kernel driver.
You need to prepare kernel driver source or binary from OSS or device vendor, first.
After that, you modify rootfs or script file.
Best regards,
Visitor sinai
Hi @watari
Thanks for your reply
I prepared well the kernel but other USB devices show only that they have been plugged in and I can see the bus addresses. so How to interact with them via USB port?
Scholar watari
Hi @sinai
You can access target device via /dev/<device name> and kernel driver, if Linux kernel and kernel driver are loaded.
I suggest you to make sure start up log file, the result of "lsusb" and "ls /dev/*".
Best regards,
Visitor sinai
Hi @watari
I will try later on
yours
Visitor sinai
The cmd
Scholar watari
Hi @sinai
After confirmation, at least, you don't satisfy kernel driver for what you wand to use.
Would you make sure it, first ?
or
Would you share start up log file about linux and the result of "/sbin/lsmod" ?
Best regards,
Visitor sinai
Rebooting... Console: switching to colour dummy device 80x30
▒eboot: Restarting system
U-Boot 2017.01 (Mar 27 2018 - 19:50:12 -0700)
Model: Zynq Zybo Development Board
Board: Xilinx Zynq
I2C: ready
DRAM: ECC disabled 512 MiB
MMC: sdhci@e0100000: 0 (SD)
Using default environment
In: serial
Out: serial
Err: serial
Net: ZYNQ GEM: e000b000, phyaddr 1, interface rgmii-id
Warning: ethernet@e000b000 using MAC address from ROM
eth0: ethernet@e000b000
U-BOOT for Zybo
ethernet@e000b000 Waiting for PHY auto negotiation to complete....... done
BOOTP broadcast 1
DHCP client bound to address 192.168.254.12 (21 ms)
Device: sdhci@e0100000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
47911808 bytes read in 4007 ms (11.4 MiB/s)
Using 'conf@1' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000d4
Data Size: 3812856 Bytes = 3.6 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: 81719700d3155539c84cfc716e730f9eeaf701a6
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Data Start: 0x103a9084
Data Size: 44072714 Bytes = 42 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 1977ee53040303a9d9a93aa09c577a5ae6058177
Trying 'fdt@0' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x103a2fc0
Data Size: 24593 Bytes = 24 KiB
Architecture: ARM
Hash algo: sha1
Hash value: a1de70019a9ba85c945b1dba7f012f168252557e
Booting using the fdt blob at 0x103a2fc0
Loading Kernel Image ... OK
Loading Ramdisk to 055f8000, end 07ffff0a ... OK
Loading Device Tree to 055ee000, end 055f7010 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 4.9.0-xilinx-v2017.4 (digilent@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Tue Mar 27 19:50:28 PDT 2018
OF: fdt:Machine model: Zynq Zybo Development Board
bootconsole [earlycon0] enabled
cma: Reserved 64 MiB at 0x1c000000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @dbbad000 s25932 r8192 d23220 u57344
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 400700K/524288K available (6144K kernel code, 208K rwdata, 1492K rodata, 1024K init, 231K bss, 58052K reserved, 65536K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0700000 (7136 kB)
.init : 0xc0900000 - 0xc0a00000 (1024 kB)
.data : 0xc0a00000 - 0xc0a34380 ( 209 kB)
.bss : 0xc0a34380 - 0xc0a6e118 ( 232 kB)
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to e0800000
slcr mapped to e0802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at e0802100
Zynq clock init
sched_clock: 64 bits at 325MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4af477f6aa, max_idle_ns: 440795207830 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 551318127 ns
timer #0 at e080a000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 650.00 BogoMIPS (lpj=3250000)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x100000 - 0x100058
Brought up 2 CPUs
SMP: Total of 2 processors activated (1300.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0840000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Freeing initrd memory: 43040K (c55f8000 - c8000000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=30 max_order=17 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 43000000.dma: Xilinx AXI VDMA Engine Driver Probed!!
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 27, base_baud = 6250000) is a xuartps
▒console [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to e0828000
[drm] Initialized
[drm] load() is defered & will be called again
brd: module loaded
loop: module loaded
m25p80 spi0.0: found s25fl128s, expected m25p80
m25p80 spi0.0: s25fl128s (16384 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000001000000 : "spare"
libphy: Fixed MDIO Bus: probed
CAN device driver interface
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 29 (d8:80:39:d3:2c:72)
RTL8211E Gigabit Ethernet e000b000.etherne:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=e000b000.etherne:01, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 23
at24 0-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
cdns-i2c e0005000.i2c: 400 kHz mmio e0005000 irq 24
uvcvideo: Unable to create debugfs directory
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at e08ec000 with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
[drm] No max horizontal width in DT, using default 1920
[drm] No max vertical height in DT, using default 1080
OF: graph: no port node found in /amba_pl/xilinx_drm
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] No driver support for vblank timestamp query.
xilinx-drm amba_pl:xilinx_drm: No connectors reported connected with modes
[drm] Cannot find any crtc or sizes - going 1024x768
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SB16G 14.8 GiB
mmcblk0: p1 p2
Console: switching to colour frame buffer device 128x48
xilinx-drm amba_pl:xilinx_drm: fb0: frame buffer device
[drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
ssm2602 0-001a: simple-card: set_sysclk error
asoc-simple-card amba_pl:sound: ASoC: failed to init 43c20000.axi_i2s_adi-ssm2602-hifi: -22
asoc-simple-card amba_pl:sound: ASoC: failed to instantiate card -22
asoc-simple-card: probe of amba_pl:sound failed with error -22
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 1024K (c0900000 - c0a00000)
INIT: usb 1-1: new full-speed USB device number 2 using ci_hdrc
version 2.88 booting
Starting udev
udevd[787]: starting version 3.2
random: udevd: uninitialized urandom read (16 bytes read)
udevd[788]: starting eudev-3.2
random: fast init done
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Populating dev cache
hwclock: can't open '/dev/misc/rtc': No such file or directory
Wed Mar 28 02:51:05 UTC 2018
Starting internet superserver: inetd.
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.24.1) started
Sending discover...
Sending discover...
macb e000b000.ethernet eth0: link up (1000/Full)
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sending discover...
Sending select for 192.168.254.12...
Lease of 192.168.254.12 obtained, lease time 7200
/etc/udhcpc.d/50default: Adding DNS 192.168.0.1
/etc/udhcpc.d/50default: Adding DNS 168.126.63.2
done.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCKFPjt+UIIoHp6kr0KrNz3Ebf1dD7AoJ5ZWxj27uRR4AsJEJ4ESR3GU4fR9hv3h2Ti9hNs5+FTsb8viLKEq9R2Viu8iXkNu8+DjzecLpyvT4ZNYSZ6kOAyU8PQIqi2GawwP0RPAU5jOT0QLB+nUk6i9AtZjEKO91ULESaDP+35N11VPn16yOi6EQU5ZbmlbElUihtI9eLnQ7jBHonGs9L3VwoLk6h+zrdngZzLMpMgdnY+tTuIfrHqbIu237/3W87Xmwl8ukkFkCnWo4igyVUMsyQPZLIAadUYIFmNGWKkKWxNJ2eH1uUTNhfKKiv5CM18u7ajxsan8psmaWrUkO/f root@Zybo
Fingerprint: md5 42:a4:8f:98:04:67:f8:42:6e:28:cf:fc:fa:ef:58:89
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
root@Zybo:~#
Visitor sinai
Hi @watari
Scholar watari
Hi @sinai
Could you execute the following command and share the result.
$ /sbin/lsmod
Could you share the result of the following command ?
$ ls /sys/bus
$ ls /sys/class
BTW, what problem are you facing ?
It seems that you don't connect any USB device from log file and the result of some commands.
Best regards,
Visitor sinai
Hi @watari
sorry for the late response
There is a LiFi receiver with a USB port. the device is from the research design lab. I would like to see it among the mounted devices so that I can get the data from it using C or C++ (serial programming).
here is the result after running the commands you told me.
regards
Scholar watari
Hi @sinai
I see.
I guess this device requires like NIC driver.
Do you have this kernel driver or firmware for linux kernel driver like WiFi driver ?
At least, if you only have source code, you need to compile it.
Also, you might have to prepare dkms.conf.
Best regards,
Visitor sinai
Hi @watari
That's write, but I just started with zynq, I am not that good, could you help me with some documentations on how to do that?
 dkms.conf and kernel conf are still more explorable for me
Btw the keyboard  fine and usb mass storage work fine.
Visitor sinai
Hi @watari thanks for your time, I appreciate it.
When the device is plugged on Windows OS it shows like usb serial(COM1, COM2, etc) which should be tty1, tty2 on linux but nothing found in all tty(s) after plugging in .
Best wishes.
Scholar watari
Hi @sinai
Got it about your situation.
BTW, I guess you need at least VCP driver as USB-UART virtual driver.
Have you already prepared it ?
If no, would you make sure it ?
Best regards,
Visitor sinai
Hi @watari
I will try that, if it doesn't work I will just look for another solution .
