zynq-7000 PS-DMA Petalinux
Where have examples of zynq's PS-DMA under Petalinux?
How to write the test app and DMA driver moduls?
The supplier of your development board might provide you with an example.
There was an example on the xilinx Linux driver page but it seems to be removed.
I suppose part of the reason is not many ppl are using the PS dma with xilinx FPGA-SoC as it can not easily access ip cores or axi streams rendering it useless for most applications.
