Newbie baul
zynq boot error Unhandled fault: imprecise external abort (0x1406) at 0x00000000
Hi all,
I am useing zynq + linux. But i have some fuse about the address map.
I have DDR 512M , Nand 128M and ramdisk16M and modify the deviceetree as this,but there are some errors:
memory {
        device_type = "memory";
        reg = <0x0 0x10000000>;
    chosen {
        bootargs = "console=ttyPS0,115200 root=/dev/ram rw  earlyprintk ip=10.105.1.101:::255.255.255.0::eth0 mem=384M  vmalloc=128M";
        linux,stdout-path = "/amba@0/uart@E0000000";
error info:
U-Boot 2012.04.01-00304-g7639205-dirty (Jan 07 2013 - 16:20:50)
DRAM:  512 MiB
WARNING: Caches not enabled
NAND:  OnDie ECC flash
128 MiB
MMC:   SDHCI: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
Copying Linux from NAND flash to RAM...
NAND read: device 0 offset 0x200000, size 0x400000
Bad block table found at page 65472, version 0x01
                        Bad block table found at page 65408, version 0x01
 4194304 bytes read: OK
NAND read: device 0 offset 0x700000, size 0x20000
 131072 bytes read: OK
Copying ramdisk...
NAND read: device 0 offset 0x900000, size 0x800000
 8388608 bytes read: OK
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.5.0-14.3-build2
   Created:      2012-10-23  18:12:23 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2725352 Bytes = 2.6 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
   Image Name:
   Created:      2012-10-03  21:10:37 UTC
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    5252189 Bytes = 5 MiB
   Load Address: 00800000
   Entry Point:  00800000
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Ramdisk to 1f659000, end 1fb5b45d ... OK
   Loading Device Tree to 1f655000, end 1f658c0b ... OK
        Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.5.0-14.3-build2 (linnj@xsjpsgv107) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #1 SMP 2
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702
bootconsole [earlycon0] enabled
cma: CMA: reserved 16 MiB at 1e000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c09a6000 s6784 r8192 d13696 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw ip=:::::eth0:dhcp earlyprintk
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 492356k/492356k available, 31932k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc048e060   (4633 kB)
      .init : 0xc048f000 - 0xc04b4a80   ( 151 kB)
      .data &colon; 0xc04b6000 - 0xc04f3c20   ( 248 kB)
       .bss : 0xc04f3c44 - 0xc051f104   ( 174 kB)
        Dump stacks of tasks blocking RCU-preempt GP.
NRZynq clock init
xlnx,ps7-ttc-1.00.a #0 at 0xe0800000, irq=43
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 512
Internal error: : 1406 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0    Not tainted  (3.5.0-14.3-build2 #1)
PC is at kernel_thread_helper+0x0/0x10
LR is at kernel_thread_helper+0x0/0x10
pc : [<c000eb40>]    lr : [<c000eb40>]    psr: 00000093
sp : df057ff8  ip : 00000000  fp : 00000000                                    _IRQS:128
r10: 00000000  r9 : 00000000  r8 : 00000000
r7 : 00000013  r6 : c000eb50  r5 : c0039194  r4 : 00000000
r3 : 00000000  r2 : 00000000  r1 : 00000000  r0 : 00000000
Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 18c5387d  Table: 0000404a  DAC: 00000015
Process swapper/0 (pid: 2, stack limit = 0xdf0562f0)
Stack: (0xdf057ff8 to 0xdf058000)
7fe0:                                                       ffffffff ffffffff
Code: 11a00150 12000001 e12fff1e c0352320 (e121f007)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x351160 - 0x351194
---[ end trace 1b75b31a2719ed1c ]---
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
Re: zynq boot error Unhandled fault: imprecise external abort (0x1406) at 0x00000000
if you've 512MB of RAM change the memory config to this
memory {
        reg = <0x0 0x20000000>;
Is that a code snippet of your devicetree? Have you tried to use a default devicetree from xilinx (e.g. for ZC702).
Also add a "loglevel=8 mminit_loglevel=4" to your bootarguments. Eventually more useful output during start...
Best regards,
Helmut
