dtrask
zynq_fsbl_bsp Regeneration Removes CVS Directory (Petalinux 2015.4)
We use CVS for version control. I have created a Petalinux project which builds and boots on the hardware, and I have placed that project under CVS control using the instructions found here: http://www.xilinx.com/support/documentation/sw_manuals/petalinux2015_4/ug1144-petalinux-tools-reference-guide.pdf (page 24)
(The only difference between these instructions and what I have done is that I have placed the $PROJECT/.petalinux/metadata file under control as it seems to be required to ensure that the project is recognized as a valid Petalinux project.)
So, I can check out from CVS and build the project without issue. However, when I run petalinux-config for any reason, the $PROJECT/components/bootloader/zynq_fsbl/zynq_fsbl_bsp seems to be removed and replaced, which deletes the CVS directory inside of it, so that the directory is no longer "connected" to the repository. So, I can no longer check in any changes under this directory.
What should I do about this?
