zynq in Git
I am trying to understand the zynq tags in xilinx git. I couldn't find any documentation for that.
I see several tags such as:
(1). zynq-soc-for-x.y (x.y is version such as 4.1) , and
(2). zynq-dt-for-x.y (x.y is version such as 4.1) .
1 . What's the difference between zynq-dt-xxx to zynq-soc-xxx ? Wwhen should we use each ?
2. Why do I see version 3.11 when using zynq-dt-for-3.12 ? and Where is zynq version 3.12 can be found ?
Thank you!
Ran
Re: zynq in Git
It depends. Upstream support for Zynq is fairly well by now, but there are differences in the feature set. This wiki page gives an idea of these differences: http://www.wiki.xilinx.com/Linux+Drivers
Re: zynq in Git
For most people the only relevant tags are the 'xilinx-v<year>.<quarter>' tags. Those are aligned with Xilinx SW releases and what is shipped in PetaLinux etc.
The vX.Y tags are the tags from upstream Linux. They are not a 'Zynq' or Xilinx version. They are identical of what you can get from kernel.org.
The zynq-...-for-x.y are used to upstream Xilinx' changes to mainline Linux. They might not even be fully functional. Don't use these unless you really know what you're doing.
Re: zynq in Git
Thank you very much.
One more thing please.
Can I assume that the version from GIT can work out of the box, without any modifications.
For example I want to use git kernel v4.0 with zynq.
Does the version from git.kernel can work or must I use xilinx version ?
Thank you!
Ran
Re: zynq in Git
Re: zynq in Git
Thank you for the table.
That's a good start for me.
It seems that git kernel used (kernel 4.x) might support everything I need for zynq (though I see in the table that ethernet might not be supported...).
I will give it a try,
Ran
Re: zynq in Git
Ethernet is supported. There are just two drivers for Zynq's Ethernet controller, one of them being upstream. It works perfectly fine with the upstream macb driver.
