zynq linux: emacps issue
I believe the 2014.2 zynq linux driver for emacps has an issue. When a TX complete interrupt is received, the interrupt status register is cleared, a tasklet is scheduled without clearing the TX status register, so that when interrupts are re-enabled, the interrupt triggers again. After happening for some time, the Linux kernel will take notice of it and offload the interrupt handler on the ksoftirqd daemon which will at last allow the tasklet to run, which clears the TX status register.
The symptoms of the problems are that when the zynq is put with a high TX load (writing on a TCP socket as fast as possible for instance), top will show that a lot of CPU time is spent in ksoftirqd.
A possible fix is to clear the TX status register in the interrupt handler, but it means that we still have another issue: we still have one irq by TX completion.
So I propose another fix, which is to disable the TX completion IRQ in the interrupt handler, re-enable it at the end of the tx_poll tasklet, and in the tx_poll tasklet, read the TX status register again before exiting in case another TX completion irq happened.
Please find attached a patch implementing this idea.
Regards.
I am not so sure about this interpretation of the ksoftirqd using a lot of cpu, especially since I have not received an answer.
The problem seems rather to be the number of TX complete interrupts. In order to avoid these interrupts I have found that
disabling the interrupt when it happens and delaying the tx_poll tasklet for 1ms, allows the tasklet to handle many packets at once, greatly reduces the number of interrupts and seems to improve (a bit) the TX performances. Please find attached the patch implementing this idea.
I am interested by any feedback on this issue.
Regards.
I'm no expert, but NAPI mode is supposed to put the driver into a polling mode when data rates get high to avoid too many interrupts. It's not clear if what you describe is a real problem or not.
John
The xilinx_emacps driver uses NAPI for RX, not for TX.
Also, without this patch, when sending as fast as possible on a gigabit link, I get something like 14000 interrupts by second. Any task which happens to be on the CPU where this happens (cpu 0) is slowed down considerably.
Thanks for clarifying about that.
