Visitor wjlbelieve
zynq linux has started up,ifconfig ,there is no eth0
kernel version I used is 3.10,and I use zynq_zc702.dts in xilinx-linx to generat the devicetree
a part of startup information:
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.10.0-xilinx-15024-gefc2750-dirty (root@ubuntu) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #7 SMP PREEMPT Wed Dec 4 23:50:42 PST 2013
Machine: Xilinx Zynq Platform, model: Xilinx Zynq
bootconsole [earlycon0] enabled
cma: CMA: reserved 16 MiB at 2e800000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @c0df8000 s8256 r8192 d16320 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260624
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw ip=192.168.0.10:192.168.0.101:192.168.0.1:255.255.255.0::eth0:off earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1024MB = 1024MB total
Memory: 1012548k/1012548k available, 36028k reserved, 270336K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0554228   (5425 kB)
      .init : 0xc0555000 - 0xc0580040   ( 173 kB)
      .data : 0xc0582000 - 0xc05bf7c8   ( 246 kB)
       .bss : 0xc05bf7c8 - 0xc05ec834   ( 181 kB)
        Dump stacks of tasks blocking RCU-preempt GP.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:16 nr_irqs:16 16
ps7-slcr mapped to f0002000
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207ms
ps7-ttc #0 at f0004000, irq=43
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 512
Setting up static identity map for 0xc03d9418 - 0xc03d9470
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
DMA: preallocated 256 KiB pool for atomic coherent allocations
xgpiops e000a000.ps7-gpio: gpio at 0xe000a000 mapped to 0xf000c000
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Switching to clocksource ttc_clocksource
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Freeing initrd memory: 4400K (dfbb3000 - dffff000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
bounce pool size: 64 pages
jffs2: version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
msgmni has been set to 1490
io scheduler noop registered
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-267056
dma-pl330 f8003000.ps7-dma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001垃薻奖晛[ttyPS0] enabled, bootconsole disabled
console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to f0062000
brd: module loaded
loop: module loaded
xqspips e000d000.ps7-qspi: master is unqueued, this is deprecated
m25p80 spi0.0: found n25q128a13, expected n25q128
m25p80 spi0.0: n25q128a13 (16384 Kbytes)
5 ofpart partitions found on MTD device spi0.0
Creating 5 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000c00000 : "qspi-rootfs"
0x000000c00000-0x000001000000 : "qspi-bitstream"
xqspips e000d000.ps7-qspi: at 0xE000D000 mapped to 0xF0064000, irq=51
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
libphy: XEMACPS mii bus: probed
mdio_bus e000b000: cannot get PHY at address 7
xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci-pci: EHCI PCI platform driver
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
xi2cps e0004000.ps7-i2c: 400 kHz mmio e0004000 irq 57
pca954x 0-0074: probe failed
xadcps f8007100.ps7-xadc: enabled:      yes     reference:      external
xwdtps f8005000.ps7-wdt: Xilinx Watchdog Timer at f006e000 with timeout 10s
zynq-edac f8006000.ps7-ddrc: ecc not enabled
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
usbhid: USB HID core driver
TCP: cubic registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
xemacps e000b000.ps7-ethernet: eth0: no PHY found
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.63 GiB (ro)
 mmcblk0: p1
xemacps e000b000.ps7-ethernet: XEMACPS mii bus mii_probe fail.
IP-Config: Failed to open eth0
IP-Config: Device `eth0' not found
Freeing unused kernel memory: 172K (c0555000 - c0580000)
Starting logging: OK
Starting mdev...
mdev: bad line 25
mdev: bad line 26
mdev: bad line 27
mdev: bad line 28
mdev: bad line 29
mdev: bad line 32
mdev: bad line 33
mdev: bad line 34
mdev: bad line 35
Initializing random number generator... done.
Starting network...
ip: RTNETLINK answers: File exists
Starting dropbear sshd: generating rsa key... generating dsa key... OK
after linux started up
# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
# ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:01:22
          BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          Interrupt:54 Base address:0xb000
does this indicate it exist net driver?
how should I solve this problem?Beacause  I just started learning embedded,I have a large amount of things to study
hope you can answer in detail,thank you for your help sincerely!
I'm sorry ,my English is so poor that I am not sure if I have  expressed  the question very well
Visitor wjlbelieve
Re: zynq linux has started up,ifconfig ,there is no eth0
Supplementary information
zynq> ifconfig eth0 up
ifconfig: SIOCSIFFLAGS: No such device or address
What board is this? Two possible causes that come to my mind:
1. The phy address in your DT is wrong? You could just brute force try different ones
2. The phy is not reset properly. Do you have the ethernet phy reset connected? I think the FSBL should then include code to toggle that signal during boot up.
Visitor wjlbelieve
Hi,sorenb,Thank you so much for your reply!
I'm sorry I'm a rookie in this field
if my phy address is wrong,how can I get the right one? and where can I make sure if my phy address is right?
how can I make sure if I have the ethernet phy reset connected? where to reset the erherner phy?
my board is zynq 7000 EES262,which maybe I think you should not have heard of
I was in accordance with the steps to generate the kernel of the xilinx official website
Regarding the phy address you could take a look at this thread http://forums.xilinx.com/t5/Embedded-Linux/boot-problem-with-xilinx-master-next-on-Zedboard/m-p/387137/highlight/false#M7343 . But if you have custom board with a different phy, you'll have to check the appropriate datasheet. Worst case, you'd have to brute force through the possible addresses.
The phy-reset is a line you would connect when you configure the PS in Vivado. When you configure the peripherals and on which pins they are, you can also select resets for the phys.
Visitor wjlbelieve
Thanks for your reply.
I think I have met the same problems with that original poster
but...
can you tell me where to modify source code like this in "xilinx-xlnx"
ps7_ethernet_0: ps7-ethernet@e000b000 {
#address-cells = <1>;
#size-cells = <0>;
clock-names = "ref_clk", "aper_clk";
clocks = <&clkc 13>, <&clkc 30>;
compatible = "xlnx,ps7-ethernet-1.00.a";
interrupt-parent = <&ps7_scugic_0>;
interrupts = <0 22 4>;
local-mac-address = [00 0a 35 00 00 00];
phy-handle = <&phy0>;
phy-mode = "rgmii-id";
reg = <0xe000b000 0x1000>;
xlnx,enet-reset = <0xffffffff>;
xlnx,eth-mode = <0x1>;
xlnx,has-mdio = <0x1>;
xlnx,ptp-enet-clock = <111111115>;
mdio {
#size-cells = <0>;
phy0: phy@0 {
compatible = "marvell,88e1510";
device_type = "ethernet-phy";
reg = <0x0>;
marvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0xa>;
Forgive me for asking such a simple problem
but...
#size-cells = <0>;
mdio {
#size-cells = <0>;
phy0: phy@0 {
reg = <0x0>;               <==== this is the phy address
Visitor wjlbelieve
mdio {
#size-cells = <0>
phy0: phy@0 {     <====when without change,the number is 7 in my source code,is there a  connection between this 0 and the following 0x0?
I tryed what that original poster refered to,
It doesn't work to me  it also has the same problem
how could I know what  phy address is  in my board ?
The node name is irrelevant, AFAIK. The reg property is essential.
Regarding your board, you have to look up the data sheets for your board's ICs. You may even have a completely different phy on the board that might require to use a different phy driver, which would mean you'd have to check whether that driver is enabled in your kernel and change the compatible string.
Newbie 00001111
Hi! I hope you can view my message.
Now I have the same question with you and I donnot how to config my kernel to make sure my ethernet to have a IP automaticly and make ethernet work.Can you give me a help!
