Anonymous
Not applicable
zynq u-boot fpga command?
I see the fpga command is supported in the u-boot of 14.2 release. Is there a link / exmaple showing how to use the command to download bitstream?
Haibing
Hi Haibing,
This was commited by the community as Xilinx has not done testing on it yet.
Hi together,
I've made some tests with the "fpga" command on U-Boot 2012.04.01
It is possible to get some informations:
zynq-uboot> fpga info 0
Xilinx Device
Descriptor @ 0x3ffb8df4
Family:         Zynq PL
Interface type: Device configuration interface (Zynq)
Device Size:    4045564 bytes
Cookie:         0x0 (0)
No Device Function Table.
But not to load the *.bit file (Original system.bit from 14.3 TRD)
zynq-uboot> fpga load 0 0x3000000 4045679
Error: Timeout waiting for FPGA to config.
fpga - loadable FPGA image support
Due to it is not fully tested, I have some doubts to head on with testing because of bricking the dev board...
To load the bitstream from Linux, the FPGA bitstream must be in a binary format and byte swapped.
Is this also the requirement for loading FPGA bitstreams from U-Boot?
I cannot find any more profound documentation regarding this issue till now.
Thanks and Regards,
Helmut
See my last mail in this topic for a simple Python script that converts a "bit" to "bin" file for direct programming:
http://forums.xilinx.com/t5/Embedded-Linux/Zynq-Loading-bitfile-into-FPGA-from-Linux-xdevcfg/td-p/237850
Seems to work fine, after loading a bin file, the "done" LED is lit. Writing the bin file takes less than a second.
zynq-uboot> fatload mmc 0 0 fpga.bin
reading fpga.bin
4045564 bytes read
zynq-uboot> fpga load 0 0 0x3dbafc
Wrong parameters for FPGA request
zynq-uboot> fatload mmc 0 0x1000000 fpga.bin
reading fpga.bin
4045564 bytes read
Xilinx Device
Descriptor @ 0x3ffb89c4
Family:         Zynq PL
Cookie:         0x0 (0)
zynq-uboot> fpga load 0 0x1000000 0x3dbafc
zynq-uboot>
Works well!
Thanks a lot!
Has anyone been able to configure PL with an encrypted bitstream from u-boot? I've booted PS in secure mode by creating an encrypted BOOT.BIN then tried to configure PL with the encrypted bitstream but u-boot fpga command just prints the help screen and the FPGA doesn't get configured. If I then run u-boot fpga command again with an unencrypted bitstream, it gets configured OK. Encrypted bitstreams do work OK from FSBL but ultimately I want to be able to configure the FPGA with encrypted bitstreams from Linux.
Niro.
Hi Niro,
unfortunately not.
But maybe the newest version of the software guide can help.
http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf
There are some topic changes regarding encryption mentioned in the revision history
Best regards,
Helmut
Hi Helmut,
Thanks for your response - Latest u-boot from Xilinx's git repository can configure PL with encrypted bitstreams. However, it only works once. Subsequent attempts to configure PL with the same encrypted bitstream fails but this was good enough for me to know that it is possible to configure PL with encrypted bitstreams outside of FSBL.
On a side note, Linux's /dev/xdevcfg driver also didn't work with encrypted bitstreams and it was causing Linux to lock-up. After some debug I found that the lock-up was by Linux being flooded with PCAP IRQs after trying to configure PL. After adding 250us of delay between assertion and deassertion of PCFG_PROG_B bit in PCAP CTRL register (used to reset PL) fixed this issue and now I am able to configure PL with encrypted bitstreams from Linux as many times as I want.
Niro.
Niro,
sounds very good that you had success.
Best regards,
Helmut
