zynq ultrascale+ MPSoc uio /dev/mem access
Dear all
is there something special regarding UIO access on zynqmp ?
I can access my IP in standalone code
but I can't use the same design in linux (petalinux2017.1)
mmap return an address that cause a fault when accessed :
unhandled level 1 translation fault (11) at 0xffffff81bce00c
should I use mmap64 ? unsigned long int *ptr ?
can I safely assume that xipname_linux.c wrapper code generated by vivado_hls 2017.1 are correct ?
regards
raph
Issue in vivado hls C wrapper. Address type is hardcoded as u32 instead of void* device descriptor
Hi @raphael.ponsard
Can you share your application code to see how are you accessing to the IP?
Ibai
Thank you for your assistance...
I am using vivado and petalinux 2017.1, and zcu102 ES2
linux code is : (same standalone code -with XPAR_ADDITION_1_DEVICE_ID in place of "addition" is running ok)
XAddition xa;
printf("XAddition_Initialize\n");
XAddition_Initialize(&xa,"addition");
printf("base address %x",xa.Bus_a_BaseAddress); printf("XAddition_Write_a_Words\n"); XAddition_Write_a_Bytes(&xa,0,t1,N*4); //access fault ERROR here
output is :
base address b7a11000
accessing address b7a11100
[   64.048922] x_hlsadder.elf[1542]: unhandled level 1 translation fault (11) at 0xb7a11100, esr 0x92000045
[   64.063045] pgd = ffffffc0746b1000
[   64.066409] [b7a11100] *pgd=0000000000000000[   64.070480] , *pud=0000000000000000
[   64.073955]
[   64.075431]
[   64.076904] CPU: 0 PID: 1542 Comm: x_hlsadder.elf Not tainted 4.9.0-xilinx-v2017
IMHO plnx-aarch64-system.dts is correct :
root@plnx_aarch64:~# cat /sys/class/uio/uio0/name
addition
root@plnx_aarch64:~# cat /proc/device-tree/amba_pl\@0/addition\@a0000000/compatible
xlnx,addition-1.0generic-uio
addition@a0000000 {
			compatible = "xlnx,addition-1.0", "generic-uio";
			interrupt-parent = <0x4>;
			interrupts = <0x0 0x59 0x4>;
			reg = <0x0 0xa0000000 0x0 0x10000>;
			xlnx,s-axi-bus-a-addr-width = <0xb>;
			xlnx,s-axi-bus-a-data-width = <0x20>;
any ideas    ?
same issue with gpio access with /dev/mem
#define GPIO_BASE_ADDRESS     	0x00A0020000
#define GPIO_DATA_OFFSET     	8   //led on gpio channel 2
#define GPIO_DIRECTION_OFFSET   12  //idem
#define MAP_SIZE 4096UL
#define MAP_MASK (MAP_SIZE - 1)
int main()
    int memfd;
    volatile unsigned int  *mapped_base;
    volatile unsigned int  *dev_base = (volatile unsigned int  *)GPIO_BASE_ADDRESS;
    printf("gpio access through mmap v0.0.4\n\r");
    memfd = open("/dev/mem", O_RDWR | O_SYNC);
    mapped_base = (volatile unsigned int *)mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, memfd, (__off_t) dev_base );
    printf("Mem address %p.\n", mapped_base);
    printf("ddr address %p.\n", (unsigned  int *)((unsigned int)mapped_base + GPIO_DIRECTION_OFFSET));
    *((volatile unsigned int *) ((unsigned  int)mapped_base + GPIO_DIRECTION_OFFSET)) = 0;
access fault :
./xgpio.elf
Mem address 0x7f982d9000.
ddr address 0x982d900c.
[  690.448153] xgpio.elf[1565]: unhandled level 1 translation fault (11) at 0x982d900c, esr 0x92000045
[  690.457286] pgd = ffffffc075b30000
[  690.460653] [982d900c] *pgd=0000000000000000[  690.464722] , *pud=0000000000000000
but design and dts are ok :
root@plnx_aarch64:~# ls /sys/class/gpio/
export       gpiochip322/ gpiochip496/ gpiochip504/ unexport
root@plnx_aarch64:~# echo 496 > /sys/class/gpio/export
root@plnx_aarch64:~# echo out > /sys/class/gpio/gpio496/direction
root@plnx_aarch64:~# echo 0 > /sys/class/gpio/gpio496/value
led0 turn OFF
root@plnx_aarch64:~# echo 1 > /sys/class/gpio/gpio496/value
led0 turn ON
Hi @raphael.ponsard
If I'm not wrong your issue might be related to the data type widths, as pointers in aarch64 are 64bit width an in one of the operation you are converting to 32bit.
If you need to do peration with the pointers do not convert them to 32 bit.
Ibai
actually I was hacking around this issue too
I did made the first tests with unsigned long int pointer that cause the same fault
I am here because I have the same issue with uio driver code generated by vivado_hls2017.1
I did assume that xipname_linux.c has wrapper for 64 bis address
I will double check
Hi @raphael.ponsard
I also realized that the DTS node that you posted does not match with the address that you used in the linux example, is it right the right address?
addition@a0000000 {
Ibai
0x00a0000000 is HLS addition IP addr
0x00A0020000 for gpio (leds) addr
What would be the correct way to mitigate it when using mmap()?
One way is to not use the aarch64 compiler but instead use the 32 bit compiler, like arm-linux-gnueabi-gcc  :)
