rogerrb1
zynq usb otg transfer size
I have usb otg configured per http://www.wiki.xilinx.com/Zynq+Linux+USB+Device+Driver and configured for otg with the gadget ethernet driver.  I can ping and run iperf test from host to zynq, but trying to connect via ssh or run iperf from zynq to host fails.  The culprit seems to be that whatever is responsible for breaking up ethernet packets in to usb packets is not working, or not configured properly.  If I set the mtu to 512 with "ifconfig usb0 mtu 512", then the ssh session is successful.  Anyone have any suggestions where I should look?
-Rick
milosoftware
It's not your fault, the driver is just broken.
At some point, the Xilinx-specific USB driver has been replaced with a generic "chipidea" one. The chipidea driver is broken.
Thanks for providing a workaround though..
milosoftware
Hmm, tried setting mtu as per your suggestion, but it won't work. Setting the mtu to 512 results in the usb ethernet not functioning at all.
milosoftware
The attached kernel patch forces a 512-byte MTU default for outgoing traffic on the gadget ethernet driver, thereby working around the problem.
milosoftware
Problem is fixed in Xilinx master-next branch:
2516e422d06d69e3432b081661dfab4b0a16656b:   usb: chipidea: add xilinx zynq platform data
Problem appeared to be the "CI_HDRC_DISABLE_STREAMING" flag.
rogerrb1
Right, applying the patch referenced here worked for me: https://github.com/Xilinx/linux-xlnx/issues/57
