zynq7000 I2C0 interrupt IRQ?
Hi,all
my board is zc706, I am confused by the zynq7000 interrupt IRQ, for example, the I2C0's IRQ number.
in the zynq-7000.dtsi file, about i2c0 as below:
i2c0: i2c@e0004000 {
            compatible = "cdns,i2c-r1p10";
            status = "disabled";
            clocks = <&clkc 38>;
            interrupt-parent = <&intc>;
            interrupts = <0 25 4>;
            reg = <0xe0004000 0x1000>;
            #address-cells = <1>;
            #size-cells = <0>;
 it shows  i2c0 IRQ number is 25.
but as ug585-Zynq-7000-TRM page 229 describration below:
Source   Interrupt Name    IRQ ID#     Status Bits           Required Type     PS-PL Signal Name     I/0
IOP                 I2C0                     57      spi_status_0[25]        High level              IRQP2F[11]           Output
 it shows  i2c0 IRQ number is 57.
who can clarify it clearly? thanks a lot in advanced
Tom
Re: zynq7000 I2C0 interrupt IRQ?
Hi Tom
Let me allow to Clarify the Interrupt Related Stuff with respect to Zynq:
Let's consider your Case:
   interrupts = < 0 25 4 >;
   interrupt-parent = <intc>; ---> Interrupt Controller GIC
Let's look into, what are these three numbers assigned to “interrupts”?
The first number (zero) is a flag indicating if the interrupt is an SPI (shared peripheral interrupt). A nonzero value means it is an SPI. The truth is that these interrupts are SPIs according to Zynq’s Technical Reference Manual (the TRM), and still the common convention is to write zero in this field, saying that they aren’t. Since this misdeclaration is so common, it’s recommended to stick to it, in particular since declaring the interrupt as an SPI will cause some confusion regarding the interrupt number.
The second number is related to the interrupt number. To make a long story short, click the “GIC” box in Vivado or XPS’s main window’s “Zynq” tab, look at the number assigned to the interrupt (57 for I2C0 ) and subtract it by 32 (57 - 32 = 25).
So, next immediate doubt is why minus 32?
(The translate function normally adds 16 to SPIs and 32 to non-SPIs, so for interrupts generated by fabric logic in a Zynq, the number in the DTS file should be the hardware number (as shown in Vivado) minus 32.)
So, put it in further short way, Get the Interrupt ID info from TRM and simply minus it with 32, and place resultant value in device tree entry of Interrupt.
The third number is the type of interrupt. Three values are possible:
  • 0 — Leave it as it was (power-up default or what the bootloader set it to, if it did)
  • 1 — Rising edge
  • 4 — Level sensitive, active high
I hope, i tried my best to clarify your doubt. Thanks
Best Regards
Shabbir
Hi Tom
  • 1 — Rising edge
Best Regards
Shabbir
 This is a very good explanation of what is in the devicetree but there is no reason you should have to edit the devicetree.  The devicetree can be automatically be generated by the xilinx tools and then you can parse the devicetree in your device driver.  The linux devicetree API's can be used to find the correct IRQ for the device.
  If you use this method you will never have to look at the TRM and try to figure out what is going on the since the tools will generate the devicetree correctly for the kernel it is built for.
jeff
Hi, Shabbir
thank your very much for your clarification, I have understood the  translate function.
another question maybe clarify it please.
            #size-cells = <0>;
what's the mean of the entry of "clocks = <&clkc 38>;"
in the device tree file zynq-7000.dtsi, have a relate to clock entry as below:
clkc: clkc@100 {
                #clock-cells = <1>;
                compatible = "xlnx,ps7-clkc";
                fclk-enable = <0xf>;
                clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x",
                        "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x",
                        "dci", "lqspi", "smc", "pcap", "gem0", "gem1",
                        "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1",
                        "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1",
                        "dma", "usb0_aper", "usb1_aper", "gem0_aper",
                        "gem1_aper", "sdio0_aper", "sdio1_aper",
                        "spi0_aper", "spi1_aper", "can0_aper", "can1_aper",
                        "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper",
                        "gpio_aper", "lqspi_aper", "smc_aper", "swdt",
                        "dbg_trc", "dbg_apb";
                reg = <0x100 0x100>;
what's the relationship between i2c0's clocks attribute and clkc node?
Tom
hi, jeff
thanks, I have got it!!!
Hi Tom,
[Satish]: This regards to clock framework used in the BSP and internally relates to Power management.
In this scenario, .dtsi is talking about SoC capabilities
from .dtsi file, clk presenting in dtsi is connected to different device clocks.
clkc: clkc@100 {
                #clock-cells = <1>;
and .dts is talking about capabilities of the specific board, in your case it is I2C0
I2C0 is connected to .dtsi file clock entry in the corr spending address.
Thanks & regards,
Satish.G
G Satish Kumar
Hi, gsatish10
thanks you, got it!!!
Tom
