Participant igal_kroyter
zynqmp high latency interrupt
I have run a small test in which a thread by setting a bit in an AXI register in the PL causing the PL to invoke a PL-to-PS interrupt. An IRQ handler is invoked and resets the register (clearing the interrupt). Two printks are utilized the first one just before the bit is set and another just after the bit is reset (one in the thread context and the second one in the interrupt handler context). The latency between the time tags of the printks is consistently 3.2[mSec].
Is there a way to reduce this value by a factor of 10 or so?
Igal
Visitor plastek
Re: zynqmp high latency interrupt
Igal,
do you printk directly to serial console?
If so then this 3.2ms delay may be due to serial port speed.
Consider storing timestamp during first and second operation, calculate difference and then print it out.
The timestamp you can obtain using do_gettimeofday function (it has usec resolution).
Andrzej.
Visitor plastek
Igal,
Andrzej.
Andrzej,
thank you for the reply.
I have tested it again per you suggestion and I received a 3[uSec] latency, which does make sense.
Igal
Visitor plastek
Great to hear that :).
Andrzej.
