zynqmp secure command
I am trying to get a feeling how "zynqmp secure" uboot command works to authenticate image.
I created an auth image via bootgen bif and gave it a go. The uboot came back to me with:
Failed: secure op status:0x11
which I think is XSECURE_ONLY_BHDR_AUTH_ALLOWED... Ok.. I have no efuses burned but since I am manually loading image from uboot prompt, I am not doing with fsbl so I dont THINK I need eFuses. My bif file is somewhat simple.. based on bootgen doc:
data_img:
[auth_params] ppk_select = 0;spk_id=0
[pskfile] psk0.pem
[sskfile] ssk0.pem
[destination_cpu=a53-0,authentication=rsa] system.dtb
I wonder what do I need to add here to get an image which can get authenticated from "zynqmp secure" ?
Re: zynqmp secure command
ok.. I think I figured it out .. needed:
[fsbl_config] bh_auth_enable
since I have no efuses programmed ...I thought I did not needed since I was not under fsbl boot sequence ...
Visitor wangyudi
Hi, BTW, how did you figure out status:0x11 means XSECURE_ONLY_BHDR_AUTH_ALLOWED? Where did you find that information?
Thanks a lot!
#define XSECURE_ONLY_BHDR_AUTH_ALLOWED 0x11
in xsecure.h
