zynqmpsoc, ultrascale, sysfs, onchip temperature sensor, PL, PS, and other Voltage sensors
Hi All,
1. Custom zynq mpsoc Ultrascale board [using 2017.1 petalinux]
2. Enabled system monitoring in zynqmpsoc
followed the link
http://www.wiki.xilinx.com/ZynqMP+AMS#Test%20Procedure-Test%20Case%201:%20Read%20channel%20value%20via%20sysfs
3. i get the values for raw, offset and scale as said in above links
cat in_temp2_pl_temp_offset
-2327
cat in_temp2_pl_temp_raw
40046
 cat in_temp2_pl_temp_scale
7.771514892
According to the above link, the calculation is as follows
scale*(raw - offset)
7.771514892*(40026-2327) = 292978.339913508
questions:-
[a] I am not sure how to interpret the above value ?
[b] Can anyone from Xilinx put out the correct way/proper notes to compute temperature values of PS,PL?
[c] can i get specific temperature values of APU, RPU in PS and Logic in PL domain?
[d]
by the way, what is the temp of remote means,
in_temp1_remote_temp_offset
in_temp1_remote_temp_raw
in_temp1_remote_temp_scale
[e] how to calculate values of voltage in VCC and other channels [ using raw, scale]?
[f] Based on Ultrascale TRM [pasted below], APU,RPU measurements are possible,  how to split/interpret the ps temp into APU and RPU temps ?
======================TRM============
Temperature Sensors
The temperature sensors are located in the following three areas of the chip.
• The LPD near the APU and measured by the PS SYSMON unit.
• The FPD near the RPU and measured by the PS SYSMON unit.
• The PL area near the PL SYSMON unit and measured by the PL SYSMON unit.
The ADC result is processed through a temperature sensor translation function to provide a
meaningful temperature value. The temperature sensor translation function and other
details of the SYSMON units are explained UltraScale Architecture System Monitor User
Guide (UG580) [Ref 6].
Re: zynqmpsoc, ultrascale, sysfs, onchip temperature sensor, PL, PS, and other Voltage sensors
   i have figured out the mistake,
the offset is wrong, the correct one shud be -36058, surprisingly the wrong offset is coming from the code, [in other words, no code changes by me]
also, i need individual temps of RPU and APU.
the equation is still correct
scale*[raw + offset] offset is in -ve [-36058]
Visitor sandroanders
Hi All,
is there any update in that? I searched thru the docs and did not find any hint about the unit of the value calculated.
root@uz3eg-iocc:~# cat /sys/bus/iio/devices/iio\:device0/in_temp0_ps_temp_raw
41616
root@uz3eg-iocc:~# cat /sys/bus/iio/devices/iio\:device0/in_temp0_ps_temp_offset
-36058
root@uz3eg-iocc:~# cat /sys/bus/iio/devices/iio\:device0/in_temp0_ps_temp_scale
7.771514892
root@uz3eg-iocc:~# echo - | awk "{print 7.771514892 * (41616-36058)}"
43194.1
what does the 43194.1 mean? °C or F or what?
Observer mrm
Is there any update on this ??
Newbie mgosavi
scale*[raw + offset] gives a value in 30000-45000 range. I don't understand what does this value mean?
After reading the datasheet UG580 V1.9 I found equations on page 40,41.
These equations can be used to calculate 16- or 10- bit ADC value from temperature in Celsius and vice versa.
Therefore, my guess was that this "scale*[raw + offset]" might be the ADC 16-bit value for temperature. But I'm not sure.
Can someone please clarify.
Visitor bdakic
According to the document:
https://www.xilinx.com/support/documentation/user_guides/ug580-ultrascale-sysmon.pdf
it looks like that your number 43194.1 is approximately T=55°C
short explanation:
number = 43194.1 is approx_number = 43194 (hex: 0xA8BA, bin: 1010 1000 1011 1010)
then you should right shift number for 6 position in order to get 10bit number
0xA8BA RSH(6) = 0x2A2 = 674 in decimal
now use equation 2-12 (page 41)
Temperature(C) = ((674 * 509.314)/(1024))-280.23 = 55.0020°C
Please correct me if I am wrong.
Observer dcherkus
Based on this discussion ) I have the following one-line copy-paste commands that can be used to look at the die temperatures from Linux:
# PS main sensor:
# Measures the LPD near the APU measured by the PS SYSMON unit.
awk '{ printf "%.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp0_ps_temp_raw
# PS remote sensor:
# Measures the FPD near the RPU measured by the PS SYSMON unit.
awk '{ printf "%.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp1_remote_temp_raw
# PL sensor:
# Measures the PL  near the PL SYSMON unit measured by the PL SYSMON unit.
awk '{ printf "%.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp2_pl_temp_raw
Note the three commands are all using the same formula, the only difference is where it is reading the sensor data from.
Here is example output for my board, with output in degrees Centigrade:
# awk '{ printf "%.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp0_ps_temp_raw
52.7
# awk '{ printf "%.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp1_remote_temp_raw
54.1
# awk '{ printf "%.1f\n", ((($1 * 509.314)/65536.0)-280.23) }' < /sys/bus/iio/devices/iio:device0/in_temp2_pl_temp_raw
60.4
Dave
This is an old post, but I like to share my own experience on this to answer an open question...
# PS main sensor:
# PS remote sensor:
# PL sensor:
52.7
54.1
60.4
Dave
In my case, your answer is consistent to the results of the following formula:
Temp = scale*(raw - offset)/1000
So if I compare the value returned by your example:
with the value returned by the following example:
T0_RAW="$(cat /sys/bus/iio/devices/iio\:device0/in_temp0_ps_temp_raw)"
T0_OFS="$(cat /sys/bus/iio/devices/iio\:device0/in_temp0_ps_temp_offset)"
T0_SCL="$(cat /sys/bus/iio/devices/iio\:device0/in_temp0_ps_temp_scale)"
TEMP_PS="$(bc <<< "scale=2; $T0_SCL * ($T0_RAW + $T0_OFS) / 1000")"
echo "$TEMP_PS"
I end up with the same result!
