Observer n.horvat
AMM Master Bridge - PS_PL Interface
is it possible to gain access to the PS (Zynq US+ MPSoc) DDR Controller from "AMM Master Birdge" IP Core which is placed in PL?
When I connect "M_AXI" port from "AMM Master Bridge" IP Core to the "HP FPD" port on the PS (Zynq US+ MPSoc), "HP FPD" port stays unconnected slave in Vivado Address Editor (option "Auto Assign Address" remains greyed out).
Attached are two images. One image represent my design block diagram and other address editor information.
Thank you.
Re: AMM Master Bridge - PS_PL Interface
IP Packager should also have a section that allows you to assign the address range (region) for your axi master interface. In your address tab, I don't see M_AXI as a master to address the ranges within the HP port.
This is because you don’t connect the avalon_s0 interface. please make it connected or external.
Observer n.horvat
I can confirm that address mapping is working while making avalon interfaces external and connecting them mannualy in hdl wrapper file.
This is ok as a workaround but I will like to have this working while making direct connection in Block Design.
I packed my avalon IP core with Vivado IP Packager and I used "Auto Infer Interface Chooser" to infer avalon signals from my IP core (check image bellow).
Is there any additional settings in Vivado IP Packager that need to be taken care of while packing a IP with avalon interface?
Observer n.horvat
Thanks for both answers! Finnaly, after IP core instantiation in Block Design, interface can be successfully mapped in Address Editor.
For those who might face similar issue:
First, in Vivado IP Packager, under "Ports and Interfaces" section, create a desired interface (it was avalon master interface in my case). Then under "Addressing and Memory" section, execute "Addressing and Memory Map Wizard". After wizard completes, specify "Range" and "Width" of the created address space. Package your IP.
Can you tell me how to add
