Participant hacmachdien
Accessing IO Pins on the FMC Expansion Card
How do read or write data on an IO Pins on the FMC card? Can I use PlanAhead to connect a signal to the IO pins on the card? Thanks in advance.
Re: Accessing IO Pins on the FMC Expansion Card
FMC is only accessible in the FPGA
to do so:
create a custom IP in your FPGA which has IN and OUTS
then you must constraint this I/O to the relevant pins of the FMC (check the datasheet), this is done in an .ucf file.
regards
G.W.,
NIST - Time Frequency metrology
Are you using evaluation board?  If yes what is the part number.
One or few banks of FPGA IO signals routed to FMC connector. Accessing those FPGA bank pins is nothing but accessing of FMC cards in most of cases.
Yes, I am using a Zynq 7000 ZC702 Evaluation Board (Part number: EK-Z7-ZC702-G). I tried to route an IO pin to a clock capable pin on the board but failed to do so. I can't measure any clock signal on the FMC IO pin that I intended to connect to.
I've just realized that my FMC has had this problem for a while (Power Good signal wasn't asserted): http://www.xilinx.com/support/answers/51438.htm.
Am I still able to use IO pins on the FMC card with this error?
This is a very old issue that was corrected, so I would be surprised if the original issue described in the answer record is present on your ZC702. I would be concerned that that something else might be wrong, so you should verify that the FMC Vadj supply is correct set to 2.5V using a voltage meter.
I have all of three power rails (VADJ - 2.5V, VCC3V3 - 3.3V, VCC_12P - 12V) measured and they all have correct values. So I guess it's fine to use the FMC IOs even though the Power Good DS5 Led is off.
