Apparent contradiction between Xilinx documents ug1209 and xapp1333 regarding PUF and RSA authentication in boot header
Page 2 of xapp1333(https://www.xilinx.com/content/dam/xilinx/support/documentation/application_notes/xapp1333-external-storage-puf.pdf) says "The RSA authentication settings cannot be stored in the boot header when using the PUF to encrypt and decrypt user data."
However...
Page 116 of ug1209(https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1209-embedded-design-tutorial.pdf) seems to do just that. `[keysrc_encryption]` is set to `bh_blk_key` while `bh_auth_enable` is set in `[fsbl_config]`
I'm inclined to believe the first document, because I was unable to get black key encryption to work with `bh_auth_enable`
Though, looking more closely, the first document says authentication settings. But what are these settings?
Can somebody clarify the meaning of the first document and correct my understanding?
